JSP carbon trunk lid for 5th gen???
i saw in a magazine a while back, i forgot which one; a carbon trunk lid on a 5th gen... i was really interested in this and i was wondering if anyone has one or knows where ic an get one, i think its made by JSP???
ne help appreciated
btw what do you guys think is a good OEM carbon hood for the lude, and what price
thx
ne help appreciated
thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted 01 SH »</TD></TR><TR><TD CLASS="quote">i saw in a magazine a while back, i forgot which one; a carbon trunk lid on a 5th gen... i was really interested in this and i was wondering if anyone has one or knows where ic an get one, i think its made by JSP???
ne help appreciated
thx</TD></TR></TABLE>
If JSP makes it, we can get it
Also the hood, call us up
http://www.robearracing.com
ne help appreciated
I got one, it's not to bad. The only problem I had was the tension bars for the trunk to pop open were just way to strong, I had to cut them out. It sucks now that it doesn't pop but o'well. If I knew how to post pics.......
Check out: speedoptions.com, go on the left hand side and go to member profiles/ rides, type in 1997, select prelude. I'm the second from the top.
How's it going with the boost project? I'm in the middle of trying to do it myself.
its done, i just have to get the car registered( i took the plates off for winter) and im waiting for my aem ems... it should have been here today
but i should be in the high 300s maybe 400 whp im going for tuning soon... well see, cause i got 550cc injectors n i dont know at what hp they will be maxed..
for my comp??you mean compression, or what did i do to get my injectors to be compatible... for compression i have 9.2 cr arias pistons 89mm and for the injectors i have RCs i ordered the clips with the injectors, soldered them in..
i think that 550's max out around 300whp.......you may need to up them if you want 400whp. if i were you i'd go with 720's or 800's.
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rseaburgh »</TD></TR><TR><TD CLASS="quote">I want to run some 450's but I'm not to sure what to do to get them compatible, what did you do for your comp?</TD></TR></TABLE>
you just need to get obd1 injector clips, and if you get high impedence injectors then you'll also need a resistor box. Have something to tune them as well........at least a V-AFC.
Compression, I'm getting some 450's off a friends eclipse what else? I'm happy with my trunk, the weaves not to bad, but the stupid manuf. put their logo into the clear coat, plus it got damaged in shipping
all in all with the hood and trunk, not to mention all the stuff out of the trunk, I lost about 90lbs give or take.
I have a VIS Carbon F hood... I think its been on the car for 2 years, ive got a chipped corner on the left top. And the hood lost its protective UV Coating.. so im in progress of buffing and Clear coating the bitch.
If anyone knows a better way to restore carbon fiber please PM me. Because the only thing i see that i can do is get er ready for clear coat.
I had the JSP carbon Trunk the Driver side was almsot half n inch higher, pretty bad gap, sold it now I'm currently using a VIS carbon trunk, better but still a bit off...
pics..
pics..
i think we did the calculations on RCeng.com, at 85% duty i think they max out at 355 whp if i remember correctly, and if you raise fuel pressure 10psi, they max out at about 410.. .either way im getting 800s in the upcoming months
MG97Prelude
Jun 24, 2006 11:15 AM
