BLINKING "D4" LIGHT! ......HELP!!!!
Old Feb 9, 2005 | 03:24 PM
vtec-adykt's Avatar
Default BLINKING "D4" LIGHT! ......HELP!!!!
recently, the "D4" light on my speedometer started flashing continuously every time i drive it. i asked a local mechanic, and he told me that it was most likely a bad tranny computer. so i purchased a used unit and installed it. it still does the same thing. what else could cause it to do that? its a 1992 honda accord dx by the way.
Old Feb 10, 2005 | 05:07 AM
JimBlake's Avatar
Default Re: BLINKING "D4" LIGHT! ......HELP!!!! (lazyeyez)
You gotta read the error codes, kinda like when the check-engine light comes on...
Probably there's a connector somewhere behind the glovebox (I don't have a '92). Jumper it with a paper clip & watch the engine & D4 lights flashing.
Long = 10
Short = 1
so.... long short short is code 12. Get it?
Post back when you read the code, but remember it DOES matter which light is flashing (maybe both with different codes).
Old Feb 10, 2005 | 05:34 AM
sj993's Avatar
Default Re: BLINKING "D4" LIGHT! ......HELP!!!! (JimBlake)
The mechanic who told you it was a bad tranny computer apparently didn't bother to check the codes.
Old Feb 10, 2005 | 06:12 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
There are a variety of causes for that to happen. Here is the chart from the Service Manual detailing the causes. This is from the 1991 model, but applies to the 1992 and 1993 model years as well. The S indicator in the 1991 is the equivilant to the D4 in the 1992 and later years.
http://www.honda.co.uk/owner/A...8.pdf
Old Feb 10, 2005 | 09:44 AM
vtec-adykt's Avatar
i did the jumper method. the check engine light stayed on, but the "D4" light blinked 7 times. it stopped, then did 7 again. so i guess the code is 7. can anyone translate the code for me?
Old Feb 10, 2005 | 10:38 AM
hondadude's Avatar
Disconnected, short, or open shift control solenoid 'A'
Old Feb 10, 2005 | 10:49 AM
vtec-adykt's Avatar
Default Re: BLINKING "D4" LIGHT! ......HELP!!!! (hondadude)
thanks bro!
92 accord guy
Jan 28, 2014 09:01 PM
elijah
Mar 14, 2006 09:03 AM
CWITR
Mar 4, 2002 12:25 PM
