knock from right rear wheel
Old Feb 9, 2005 | 02:49 PM
Hcivic88's Avatar
Default knock from right rear wheel
I own a 1988 honda civic hatchback
for a while now, ive been getting a pretty loud knocking, just from the right rear wheel, every little bump i hit, it knocks.. I put brand new springs and shocks on, thinking it could have been bad shocks, but still the exact same noise.
I'm running out of ideas, what else can I check back there that might be making the noise?
thanks a lot
Old Feb 9, 2005 | 02:51 PM
untitled's Avatar
Default Re: knock from right rear wheel (Hcivic88)
Rear sway bar maybe rattling or knocking around under compression.
Old Feb 9, 2005 | 02:53 PM
Hcivic88's Avatar
Default Re: knock from right rear wheel (untitled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitled &raquo;</TD></TR><TR><TD CLASS="quote">Rear sway bar maybe rattling or knocking around under compression. </TD></TR></TABLE>
there is no rear sway bar on my car, its a DX, but good guess anyways
Old Feb 9, 2005 | 03:00 PM
untitled's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic88 &raquo;</TD></TR><TR><TD CLASS="quote">there is no rear sway bar on my car, its a DX, but good guess anyways</TD></TR></TABLE>
hrm, maybe exhaust hitting, maybe uca is loose &lt;--
Old Feb 9, 2005 | 03:17 PM
ssl2k's Avatar
Did you put everything together correctly?
Old Feb 9, 2005 | 03:18 PM
ssl2k's Avatar
Also, How the **** are we suppose to know? Why dont you get under there and look.
That's like saying my *** itches....where should I scratch?
Old Feb 11, 2005 | 02:33 PM
Hcivic88's Avatar
Default Re: (ssl2k)
I did go under there and look.. and i checked all the bolts everything is tight.. i grabbed the lca and tried shaking it, no noise.. and i can bounce the car in the back and it doesnt make any noise either.. so trust me, i have looked.. many times.. i just cant seem to find the problem
hrm, maybe exhaust hitting, maybe uca is loose &lt;-- </TD></TR></TABLE>
that is a possibility.. i actually tried that tho.. at first.. i could take the exhaust, and if i shook it enough.. it would infact bang against the bottom of the car.. although i changed the hanger on it.. and now it takes A LOT of force to get it even close to hitting the car.. although i guess its still a possibility. I'll check that out tomorrow when im under there
Old Feb 11, 2005 | 02:41 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (Hcivic88)
Bushings?
Maybe something loose in the drum brakes?
Old Feb 11, 2005 | 02:54 PM
crxgator's Avatar
check your rear trailing arm bushing, its that big *** one that holds the entire trailing arm to the chassis...
jjr_99prelude
Oct 17, 2007 06:53 PM
Team RS2
May 5, 2007 01:24 PM
HondaScott
Honda Civic (2001 - 2005)
21
Apr 28, 2007 03:37 PM
deviant1
May 20, 2004 01:47 AM
abeaujuin
Nov 13, 2003 05:08 AM
