clunking noise from rear
after installing my h&r race springs on my illuminas (EK), there is a clunking sound from the rear when hitting a sharp bump. the nut on top of the strut assembly is tight. everything else was bolted down to proper torque specs. i have clearance for my rear sway bar and exhasut. i dont know what could be causing it.
Modified by deviant1 at 10:43 PM 5/19/2004
Re: clunking noise from rear (deviant1)
yeah it could just be the coils rubbing when they are compressed.
there is a product out there (i dont know what it's called) but it's like a plastic strip that you wrap around the coils so when they rub it's plastic on plastic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 »</TD></TR><TR><TD CLASS="quote">bumpstops are cut to 1" on all corners. i also dont think its the sway bar. not really sure. maybe coils hitting each other?</TD></TR></TABLE>
coils hitting each other = coil bind = not good
i don't think H&R would produce a spring that this happened too. most of the time this happens with heated or cut springs
Team Bukkake Sucks!!!
42
01-14-2008 07:05 AM
