HOW TO: install SRR ignition switch??? (searched already)
Old Feb 9, 2005 | 01:00 PM
RuthlessEF-9's Avatar
Default HOW TO: install SRR ignition switch??? (searched already)
Please help...looking to buy one of these, but I asked if it came with instructions and they said no. So I want to see if I can get instructions first before I purcahase it
thanks
Old Feb 10, 2005 | 12:13 PM
Default Re: HOW TO: install SRR ignition switch??? (RuthlessEF-9)
I know someone knows how
Old Feb 11, 2005 | 04:11 AM
EE_Chris's Avatar
Is it like a push-button stater switch - like what the S2K uses? If yes, do a Google for the S2K switch.
Kinda hard to believe that a company would produce something with no documentation for it....is this a private seller?
Old Feb 11, 2005 | 06:21 AM
SlowReaction's Avatar
Default Re: HOW TO: install SRR ignition switch??? (EE_Chris)
If you were closer to me i'd help you install it. Kinda hard for me to explain how to wire it up but I'll take a look at my car later and see if I can make a diagram. Btw its the switch panels with the toggle switch and push button correct?
Old Feb 11, 2005 | 11:01 AM
Default Re: HOW TO: install SRR ignition switch??? (SlowReaction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">If you were closer to me i'd help you install it. Kinda hard for me to explain how to wire it up but I'll take a look at my car later and see if I can make a diagram. Btw its the switch panels with the toggle switch and push button correct?</TD></TR></TABLE>
Yes it is..all im worried about is the toggle part..I know how to do the just the push button. But not the toggle.. cause to my knowledge the toggle is suppose to turn on the ignition as if you were turn the key in the "on" position.
Thanks for the help<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Is it like a push-button stater switch - like what the S2K uses? If yes, do a Google for the S2K switch.
SRR makes the switch panel.. good company products.. and its a push button with a toggle that the only reason why I asked for help....
Kinda hard to believe that a company would produce something with no documentation for it....is this a private seller?</TD></TR></TABLE>
Old Feb 11, 2005 | 05:44 PM
machine4321's Avatar
yea ..youll need a diagram to find your ignition wire...you can do this 2 ways
1... run 1 wire from you constant wire in the ign harness to the toggle switch and then run the other side of the toggle to the ign wire
thats the race way
2. for added protection from theft you can cut the ign wire from the harness and add a wire to each end you just cut ...both will go to the toggle switch ..but it will only be functional when the key is in the "on" possition ..
so you would turn key to on and then flip togg;le to on and hit your start button ...hope that worded out ok any more questions let me know
Old Feb 13, 2005 | 11:29 AM
Default Re: (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">yea ..youll need a diagram to find your ignition wire...you can do this 2 ways
thats the race way
so you would turn key to on and then flip togg;le to on and hit your start button ...hope that worded out ok any more questions let me know </TD></TR></TABLE>
any picture diagrams??? I kinda understand..
Old Feb 15, 2005 | 08:38 AM
sorry man i have none
but the ignition harness is only 3 wires
one contant power
one igntion and one for start
there all thikn and coulrs will be white/blck stripe
black yellow stripe
black and white stripe
Old Feb 15, 2005 | 02:42 PM
Perpetual Concepts's Avatar
You're best bet is to go and talk with an alarm installer. They generally have the wiring diagrams for most vehicles.
DO/\/\O
27
Dec 11, 2010 10:10 AM
Top-Fuel
Mar 10, 2005 01:21 AM
Top-Fuel
13
Dec 15, 2004 02:01 PM
davidnyc
Jun 18, 2004 04:05 PM
