Help with Oil pressure gauge install
Old Feb 9, 2005 | 12:00 PM
dohcivichatch's Avatar
Default Help with Oil pressure gauge install
I just bought an electric auto meter oil pressure gauge... Not to sure where to screw in the sender... the instructions that came with the gauge is very vague and I want to get a good reading... Anyone already have on hooked up
Old Feb 9, 2005 | 12:23 PM
kappa12's Avatar
Default Re: Help with Oil pressure gauge install (dohcivichatch)
This outlines the most effective and safest way to mount the sender:
http://www.theoldone.com/articles/oilpressure/
Good luck.
Josh
Old Feb 9, 2005 | 03:06 PM
Default Re: Help with Oil pressure gauge install (kappa12)
Well what i have does not look like any of that... I don't have to run any lines... I would post pics but i can never seem to get them to come up... Its a electric gauge not mechanical
Old Feb 9, 2005 | 06:29 PM
mmuller's Avatar
Mad Scientist
you need a 1/8 bspt to npt adapter; 1/8 line into a distribution block and put your senser there.
just like the link.
Old Feb 11, 2005 | 04:53 AM
kappa12's Avatar
I know yours is electric, otherwise you wouldn't have a sending unit. The point of running lines is to mount the sender somewhere other than directly off the block. When mounted to the block the senders tend to snap off. Do a search and you will see that other people recommend remotely mounting it as well.
mmuller is right about the npt to bspt adaptor. You can find them on the McMaster Carr (http://www.mcmaster.com) website.
Josh
lude98SH
Jan 6, 2008 10:19 AM
ZXRider
Sep 11, 2006 11:49 PM
oo3
Jun 3, 2006 10:00 PM
One8Hatch
Dec 25, 2001 12:09 AM
