Heater box
Old Feb 9, 2005 | 10:33 AM
drift9's Avatar
Default Heater box
i have removed the dash and taken every bolt out that i can find, clips and everything but i still cant get it out i need to get this out because im doinn an integra dash swap and nned to change the white box for the vents. Any help please i can t find out then i have a cordless sawsall that can tell me.
Old Feb 9, 2005 | 10:57 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Heater box (drift9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift9 &raquo;</TD></TR><TR><TD CLASS="quote">i have removed the dash and taken every bolt out that i can find, clips and everything but i still cant get it out i need to get this out because im doinn an integra dash swap and nned to change the white box for the vents. Any help please i can t find out then i have a cordless sawsall that can tell me. </TD></TR></TABLE>
Hahaha. The heater box (or heater core and blower motor as well call them here in the states) are connected to the engine via the coolant/heater hoses from the block. It would be quite difficult to remove the apparatus without first disconnecting these lines and pushing the heater core bungs and grommet back through the firewall.
Old Feb 9, 2005 | 11:03 AM
JDMH22HATCH's Avatar
Default Re: Heater box (Archidictus)
There is also a nut on the firewall (engine bay side) that secures the heater core to the firewall underneath the heater hoses. So after you have removed the heater core hoses, undo the nut and the core should be able to be pulled out. (assuming you unbolted everything from the inside
Old Feb 9, 2005 | 11:09 AM
jlacoy82's Avatar
71.192.16.183
Default Re: Heater box (JDMH22HATCH)
This might help as well maybe?
https://honda-tech.com/zerothread?id=605432
rayrayx11
Oct 14, 2013 05:18 AM
90civichb
Feb 19, 2005 09:22 PM
ecksman
Apr 2, 2004 07:42 PM
dAng! Kris
Feb 19, 2004 12:50 PM
Stryker908
Aug 26, 2002 01:58 PM
