Valve Cover question.....?
Old Feb 9, 2005 | 09:46 AM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
Default Valve Cover question.....?
A friend of mine just gave me a OEM GSR valve cover. I wanted it for the cam gear adjustment so I don't hack up a true ITR valve cover... But rather than a "half moon" or just cutting the very end portion off, He has cut the whole end section off that covers the top of his timing belt..... Should I use it or find me one that has not been cut or has a half moon.... Dont know if there could be a potential problem or not if I were to use it..... I don't really feel comfortable with the idea of having an exposed timing belt..... Comments and thoughts are welcome. Just dont flame me please... I turn to you guys outta trust and reliability.
Old Feb 9, 2005 | 09:48 AM
ZygSpeed's Avatar
Default Re: Valve Cover question.....? (01ITR#173DC2ning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01ITR#173DC2ning &raquo;</TD></TR><TR><TD CLASS="quote">I wanted it for the cam gear adjustment so I don't hack up a true ITR valve cover... </TD></TR></TABLE>
Simple, install it for tuning purposes and then put your stock (uncut) valve cover on after you're done.
Opie's Avatar
If you are using it for cam tuning it is fine, I've seen people actually drive with vavle covers that have been hacked like that with no problems.
IMO, you should get to the shop, then swap covers and swap back when you're done
Old Feb 9, 2005 | 09:51 AM
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">If you are using it for cam tuning it is fine, I've seen people actually drive with vavle covers that have been hacked like that with no problems.
IMO, you should get to the shop, then swap covers and swap back when you're done </TD></TR></TABLE>
My intentions with this exactly..... Thanks guys
Old Feb 9, 2005 | 09:55 AM
Opie's Avatar
******' ricer
Old Feb 9, 2005 | 09:57 AM
Chris F's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">******' ricer </TD></TR></TABLE>
<FONT SIZE="20">GTFO!</FONT>
Wait.. what?
Old Feb 9, 2005 | 10:00 AM
Thanks for opinions guys.....
Old Feb 9, 2005 | 10:13 AM
white rocket's Avatar
When I got my cam gears installed I had the shop cut my valve cover to show the gears. Not only for tuning when I get Hondata but also so I can "rice on" with my bad self. I've had no problems but if you live in a cold/salty environment the cam gear bolts will oxidize.
Old Feb 9, 2005 | 10:16 AM
Default Re: Valve Cover question.....? (white rocket)
is your timing belt exposed?
Old Feb 9, 2005 | 10:41 AM
Here are a couple of pics. The cover was cut and the top peice of the timing belt cover was removed. You'll also notice the oxidized bolts, which so far has been the only downfall but they should clean up well once I get around to it. BLING ON
Old Feb 9, 2005 | 12:21 PM
B2FiNiTY's Avatar
What is the best way to get the moon cuts?
Old Feb 9, 2005 | 12:26 PM
Default Re: Valve Cover question.....? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">What is the best way to get the moon cuts? </TD></TR></TABLE>
There are a couple of companies that sell pre-cut moon shaped valve covers or you can just use a hole saw with the appropiate size bit.
Old Feb 9, 2005 | 12:41 PM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
Simple, install it for tuning purposes and then put your stock (uncut) valve cover on after you're done. </TD></TR></TABLE>
i agree, but i liked having the open end to occasionally check the adj. cam gear bolts.... to make sure they stayed tight
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">
There are a couple of companies that sell pre-cut moon shaped valve covers or you can just use a hole saw with the appropiate size bit.</TD></TR></TABLE>
exactly the way i cut mine w/ a hole saw and a couple c-clamps holding the cover down on a bench....
Old Feb 9, 2005 | 12:44 PM
B2FiNiTY's Avatar
Got pics of this hole saw? Does it look like a cup?
Old Feb 9, 2005 | 12:50 PM
cmdr430's Avatar
Got pics of this hole saw? Does it look like a cup? </TD></TR></TABLE>
it looks like this..... there are different variations
Old Feb 9, 2005 | 12:59 PM
http://www.irwin.com/irwin/con...00005
Just sumthin' I found on Google but you get the idea.
Old Feb 10, 2005 | 07:26 PM
is that the new style AEM cam gears..?
Old Feb 10, 2005 | 10:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01ITR#173DC2ning &raquo;</TD></TR><TR><TD CLASS="quote">is that the new style AEM cam gears..?</TD></TR></TABLE>
Yuppers!!!
Old Feb 11, 2005 | 03:23 PM
IntegraXTR's Avatar
or you can:
http://cgi.ebay.com/ebaymotors...33627
haha i dunno
Old Feb 11, 2005 | 03:37 PM
.water's Avatar
ya i like moon cut that sells in ebay..
Old Feb 11, 2005 | 07:17 PM
gsr-2nr's Avatar
Default Re: Valve Cover question.....? (Chris DC2)
well unless you have a jdm valve cover ther is nothing special about the itr valve cover its just a gsr cover but its red so hack away
Old Feb 11, 2005 | 08:35 PM
Aquafina's Avatar
Default Re: Valve Cover question.....? (gsr-2nr)
D series owns. Just take the timing belt cover off.
D series swap bandwagon has begun.
jaje
Nov 11, 2009 10:22 AM
GrnZ
Apr 10, 2008 11:52 AM
alotawatts
10
Dec 20, 2004 09:51 AM
JeremyL
Apr 16, 2003 10:10 PM
ykracing
Feb 22, 2003 02:25 PM
