What transmission cases are interchangeable with a 92 gsr trannny?
well, no. you can use the internals of the ys1 in a hydro tranny.
you cannot swap it with an older cable tranny case though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">well, no. you can use the internals of the ys1 in a hydro tranny.
you cannot swap it with an older cable tranny case though</TD></TR></TABLE>
Older being another 92-93 YS1 (ls or gsr).
I don't think you can swap a newer YS1 case with a pre '92 b series cable tranny (ie s1, j1, y1, etc.)
HTH
Adam
HTH
Adam
Are you saying I can only swap the internals into a hydro case or a gsr? Is ys1 the code for the 92 gsr? Can I swap it into a jdm b16 case?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 »</TD></TR><TR><TD CLASS="quote">
HTH
Adam
</TD></TR></TABLE>SO can I use any 92 or 93 case?
HTH
Adam
Go to http://www.acuraautomotiveparts.org (or net?). Look up the Acura part number for a 92 GSR transmission case. Then look up the part # for a Teg LS with a YS1. If they're the same, swap away.
Just an idea.
I believe the S1/J1 use smaller bearings and syncros, search it has been covered.
Just an idea.
killerpenguin21
Dec 7, 2006 08:58 PM
TeamSTEALTH GSR
Jun 15, 2003 04:33 PM
