Have You Thrown a Rod in a B Series Engine?
Old Feb 9, 2005 | 07:18 AM
SMSP's Avatar
Default Have You Thrown a Rod in a B Series Engine?
If so, which cylinder?
I have a hunch
Please don't vote for hydrolock.
Modified by SMSP at 8:43 PM 2/9/2005
Old Feb 9, 2005 | 07:20 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: Have You Thrown a Rod in a B Series Engine? (SMSP)
is this hunch related to your H1 motor? and are you going to be ready for VIR?
Old Feb 9, 2005 | 10:27 AM
IN VTEC's Avatar
Thrown a rod? As in broken or tossed completely out of the motor?
Are you also including events that involved damaged rod bearings, but nothing else more serious?
Old Feb 9, 2005 | 10:31 AM
Micro's Avatar
I don't remember exactly which one is was, but a customer brought in a GSR with a hole in the block, and it was either #2 or #3 one of the middle ones. This was a completely stock B18C1 running 100 shot of Nitrous.
And it snapped off towards the bottom and most of it wasn't found inside the motor... so most of it probably flew out of the block (front (header) side)
Old Feb 9, 2005 | 10:40 AM
polymath's Avatar
I've broken an Eagle rod and shot it out of the block...cylinder #3.
Old Feb 9, 2005 | 11:53 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Have You Thrown a Rod in a B Series Engine? (Coyote1800cc)
Hmm, so far all of the votes are for #3.
Old Feb 9, 2005 | 12:11 PM
CHEETAH's Avatar
dave, always #3 and rods always throw out of the same spot of the front and back of the block ... you should ask for pics too ...
greg
Old Feb 9, 2005 | 12:31 PM
crazyitr's Avatar
#3, Who cares about the rod! Thank God nothing happened to the SMS header!
Shameless plug for my buddy Dave
Old Feb 9, 2005 | 02:52 PM
Digga4's Avatar
Default Re: Have You Thrown a Rod in a B Series Engine? (crazyitr)
Can we say HYDRO-LOCK... that was my first experience
Science 101
H 2 O + CAI + Florida = hydrolock
Old Feb 9, 2005 | 07:03 PM
xtrafastcivic's Avatar
Default Re: Have You Thrown a Rod in a B Series Engine? (Digga4)
it's always #3 now someone go figure out why #3 and find a solution thanks ... :D
Old Feb 9, 2005 | 07:16 PM
SMSP's Avatar
Default Re: Have You Thrown a Rod in a B Series Engine? (XtraFastCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtraFastCRX &raquo;</TD></TR><TR><TD CLASS="quote">it's always #3 now someone go figure out why #3 and find a solution thanks ... :D</TD></TR></TABLE>
Well this is helping to prove my hunch. There are a couple of solutions, I'm just looking into the cheapest way to do it.
Old Feb 9, 2005 | 07:19 PM
CompressionFed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
Well this is helping to prove my hunch. There are a couple of solutions, I'm just looking into the cheapest way to do it.</TD></TR></TABLE>
What are the possible solutions?
Old Feb 9, 2005 | 07:28 PM
SMSP's Avatar
Default Re: Have You Thrown a Rod in a B Series Engine? (CompressionFed)
One first has to know why its usually #3 that fails.
Think out loud.
What are some of the causes of rod failure?
Old Feb 9, 2005 | 07:29 PM
Oil starvation...(bearings) #3 is also the hottest cylinder, but I'm not sure if that matters much in respect to the rod.
Old Feb 9, 2005 | 07:40 PM
JdmEKCivic's Avatar
poor bearing clearance? improper/weak rod bolts?
Old Feb 9, 2005 | 07:55 PM
Micro's Avatar
I'm thinking that it might be #3 because of the way the crank dynamics are working. Try and understand my thinking here (Im thinking out loud, so this might come out weird) There is more support on #'s 1&2 from the tranny/flywheel... #3 is right at the end of the girdle (GSR/ITR motors) with the only support coming from the main cap... then #4 has the crank pulley near it, and the oil pump close by so it's staying pretty harmonic....
i'll take a guess by saying the the crank might actually be vibrating more at #3, so thats what might be helping to cause the failure.
I think on an LS block this will be more common... but in my experience at the shop... only B18C1 GSR motors have this dillema.
Old Feb 9, 2005 | 08:57 PM
lohatch's Avatar
my buddies gsr wrecked havoc on the #3 cylinder as well. punched half the sleeve out.
Old Feb 9, 2005 | 09:44 PM
JoeB18R's Avatar
Default Re: Have You Thrown a Rod in a B Series Engine? (lohatch)
i threw a bearing in my B16 hence why i got the bad *** motor swap. not a rod, but put the engine out of comission just as well.
Old Feb 9, 2005 | 10:13 PM
hybrid_vtec's Avatar
I have thrown a motor in 2 different motors, both on cylinder #3
Old Feb 9, 2005 | 10:15 PM
rjay8604's Avatar
Default Re: Have You Thrown a Rod in a B Series Engine? (JoeB18R)
Also doesn't honda give rod #3 different clearance specs, oh wait that the third main
Old Feb 9, 2005 | 10:29 PM
IN VTEC's Avatar
Default Re: Have You Thrown a Rod in a B Series Engine? (IN VTEC)
I have to put my vote in on cyl #1 for me. I chewed up that rod bearing while auto-x'ing. All of the other bearings were fine.
Old Feb 9, 2005 | 10:30 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I have to put my vote in on cyl #1 for me. I chewed up that rod bearing while auto-x'ing. All of the other bearings were fine.</TD></TR></TABLE>
Must have been oil starvation.
Old Feb 9, 2005 | 10:45 PM
IN VTEC's Avatar
Default Re: Have You Thrown a Rod in a B Series Engine? (rochesterricer)
The motor had a Mugen baffled pan and an oil pump with gerotors that clearanced out ok. It ran fine for 25k miles and ran several auto-x's over the last two years at the same site (similar course design every time), as well as drag racing occasionally and including one HPDE a couple months before the motor gave out.
The #1 rod is the closest to the oil pump output as well. I can see the #2 or #3 rod bearings having an oiling problem since they're only fed by one main journal each, but not the #1 rod.
Old Feb 9, 2005 | 10:59 PM
untitled's Avatar
Its very interesting that most of the occurences are with rod #3.
Old Feb 9, 2005 | 11:30 PM
TOR's Avatar
TOR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Digga4 &raquo;</TD></TR><TR><TD CLASS="quote">Can we say HYDRO-LOCK... that was my first experience
Science 101
H 2 O + CAI + Florida = hydrolock </TD></TR></TABLE>
I bought a 91 integra with the same problem Hydro-d only this one had a stock intake. Anyways Rebuilt that engine (same crank beleive it or not) and then 20K later I spun Rod #3 mine was def oil starvation.
I also built a LS motor and spun Rod#3 within 400 miles of rebuild. So I have two #3's.
