Need advice .. AEM SRI vs INJEN SRI
Old Jan 16, 2002 | 12:51 PM
ShadowRSX's Avatar
New User
Default Need advice .. AEM SRI vs INJEN SRI
Whats up everbody...
Ok, here is my dilemma:
I have the RSX 5spd, base model. and im in the ever eternal quest for hp, so here is my question..
In a sea-level application, what is a better buy, the Injen SRI, or the AEM SRI .. What produces more HP, what sounds better, etc..
if anyone has them installed .. can you please give me your feedback on it -- any comments are welcome.
Thanks Guys!
Old Jan 16, 2002 | 01:17 PM
Tubincuban's Avatar
Default Re: Need advice .. AEM SRI vs INJEN SRI (ShadowRSX)
I was hoping for similar advice myself. After consulting several local speed shops, I noticed a trend in the responses I received. They all said that either the AEM or Injen would produce nearly identical performance and audible aspects when installed. Most likely they both use similar if not identical filters, and re-route the air in a similar pattern. I would recommend going with which ever you can get for a better price.
[Modified by Tubincuban, 10:22 PM 1/16/2002]
[Modified by Tubincuban, 10:24 PM 1/16/2002]
[Modified by Tubincuban, 10:25 PM 1/16/2002]
Old Jan 16, 2002 | 02:43 PM
SlowPoke's Avatar
New User
Default Re: Need advice .. AEM SRI vs INJEN SRI (Tubincuban)
Both are good intakes, but I would go for the Injen
Old Jan 16, 2002 | 03:29 PM
ShadowRSX's Avatar
New User
Default Re: Need advice .. AEM SRI vs INJEN SRI (SlowPoke)
awesome .. thanks guys -- just FYI though --
i can get a group buy deal through groupbuyonline for the AEM for 169.00 and the injen isnt dropping below 220.00 for me anywhere i look .. if they are as similar as you guys say, the the choice is clear..
... thanks again!
Old Jan 16, 2002 | 04:48 PM
JDM_DOHC_SiR's Avatar
New User
Old Jan 16, 2002 | 07:18 PM
AceP97's Avatar
New User
I have the AEM on my Base RSX and I love it. The injen claims to make all of this power, but I find that hard to believe. I mean it is just an intake. Either one will be just fine. I think the AEM looks better, but then again nobody can see under your hood. As far a s sound goes it is not much louder than stock. I think at WOT the stock intake might have been slightly louder. It is pretty deep and you can hear it sucking air big time. I have the magnaflow catback also and it has worked well for me. Decent power gains in the mid to upper rpm range. Regardless, $220 for an short ram intake is kind of high. Injen does make good products though, I just trust the quality of AEM more. Good Luck!
Old Jan 17, 2002 | 08:41 AM
JUNIOR's Avatar
Default Re: Need advice .. AEM SRI vs INJEN SRI (RacerXWannaB)
this is from a pervious post
https://honda-tech.com/zerothread?id=108707
there is a link that show the dnyo results
Old Jan 17, 2002 | 09:11 AM
SHFTAT8's Avatar
Default Re: Need advice .. AEM SRI vs INJEN SRI (biggest_dookie)
The injen also comes with a heat shield which should be the reason for the higher price. Personally I'm gonna hold out for the Comptech ice box and see what kind of power they were able to make with it. Comptech=
Old Jan 17, 2002 | 09:18 AM
JUNIOR's Avatar
Default Re: Need advice .. AEM SRI vs INJEN SRI (SHFTAT8)
at modacar.com the injen is 210.00 aem is 290.00
Old Jan 17, 2002 | 11:15 AM
ShadowRSX's Avatar
New User
Ok, just got off the phone with Daniel at modacars.com, thanks so much for suggestion and the site -- they are selling the intake for about $30-60 less than anywhere else ive looked. Worth a call if you guys need the intakes -- Ill give a quick note back once i get it..
For Biggest_Dookie ....
Old Jan 17, 2002 | 11:24 AM
JUNIOR's Avatar
Cool
DeDonDeRosa
Honda Civic (2006 - 2015)
30
Feb 21, 2007 04:26 PM
munscher
Sep 15, 2002 07:40 PM
hb_racer
16
Jul 17, 2002 04:00 AM
TeamTooQuick
Apr 24, 2002 11:07 AM
snake01
Mar 19, 2002 01:16 PM
