TILTON TWIN-DISC!!! HELP!!!
Old Feb 8, 2005 | 09:10 PM
TURBO4drTypeR's Avatar
Default TILTON TWIN-DISC!!! HELP!!!
Im having problems with my tilton and was wondering if anyone has faced this? It's a full Tilton clutch kit w/hydro t/b kit that I have. When I sit still the pedal feels fine, I put it into gear and the pedal gets stuck to the floor and wont come back up... I need help guys !!!
Thanks
Old Feb 8, 2005 | 09:17 PM
ekb16's Avatar
did you bleed your clutch alot of times b4 you started it up.
Old Feb 8, 2005 | 09:24 PM
Default Re: (ekb16)
Yes. Ive been driving it on the street for 2 months just fine! Then all of the sudden this problem occured tonight... I dont know what it could be??? I even bled the clutch again(actually flush the whole clutch fluid) I dont think its the pressure plate???? I think its the clucth master but i dont see any leaks
Old Feb 8, 2005 | 09:41 PM
mmuller's Avatar
Mad Scientist
Default Re: (ekb16)
maybe your hydraulic release bearing took a ****?
Old Feb 9, 2005 | 08:40 AM
Default Re: (mmuller)
Yea I hope you're right along with my hopes of it being a simple leak or anything along the T/B kit... Those parts are way cheaper than the clutch
Old Feb 9, 2005 | 01:18 PM
Default Re: (TURBO4drTypeR)
Anyone else have ideas or opinions?
Old Feb 9, 2005 | 07:52 PM
Anyone???
Old Feb 9, 2005 | 09:54 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">maybe your hydraulic release bearing took a ****?</TD></TR></TABLE>
I agree
Old Feb 9, 2005 | 10:44 PM
JL's Avatar
JL
Default Re: TILTON TWIN-DISC!!! HELP!!! (TURBO4drTypeR)
so wait, when you "sit still" do you mean in neutral? can you depress the clutch pedal and it will come back up? or once you press the clutch pedal down it doesn't come back?
Old Feb 10, 2005 | 07:21 PM
Default Re: TILTON TWIN-DISC!!! HELP!!! (JL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL &raquo;</TD></TR><TR><TD CLASS="quote">so wait, when you "sit still" do you mean in neutral? can you depress the clutch pedal and it will come back up? or once you press the clutch pedal down it doesn't come back?</TD></TR></TABLE>
When it's in nuetral the pedal will feel fine... When I put it in gear and try to drive off it gets stuck to the floor
Old Feb 11, 2005 | 07:05 AM
Old Feb 11, 2005 | 07:12 AM
SlowReaction's Avatar
Is there presure when you step on it? or does it just drop straight to the floor? I've never seen the hydro t/b but how do you bleed it?
roli
May 25, 2009 01:48 PM
HondaKyle
Honda S2000
12
Apr 24, 2009 06:59 AM
SOHCex20
May 31, 2005 01:47 PM
ls95hatch
May 24, 2003 09:34 PM
DOHCarp
12
Jul 30, 2002 10:28 AM
