ABS D series axles work in non ABS D?
Old Feb 8, 2005 | 07:43 PM
deviant1's Avatar
Default ABS D series axles work in non ABS D?
Will ABS D series axles work in a non ABS D series civic? and vice versa...
Old Feb 8, 2005 | 07:46 PM
92SiBlu's Avatar
Default Re: ABS D series axles work in non ABS D? (deviant1)
yes it will work... the only difference is the splines are on it... but if you dont have teh sensors or the splined hub there is no problem... i had abs axles on my hb with gsr for a while
Old Feb 10, 2005 | 10:35 AM
boostin1cam's Avatar
Default Re: ABS D series axles work in non ABS D? (92SiBlu)
so gsr abs axles will work on a civic with a gsr? cuz someone told me it wouldn't
Old Feb 10, 2005 | 10:38 AM
dwnthehatch's Avatar
Default Re: ABS D series axles work in non ABS D? (93civcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civcoupe &raquo;</TD></TR><TR><TD CLASS="quote">so gsr abs axles will work on a civic with a gsr? cuz someone told me it wouldn't</TD></TR></TABLE>
They were wrong.
Old Feb 10, 2005 | 10:44 AM
Default Re: ABS D series axles work in non ABS D? (dwnthehatch)
thanks man i appreciate it
Old Feb 10, 2005 | 10:47 AM
dantastic's Avatar
i have GSR ABS axles on my b18b hatch
Old Feb 10, 2005 | 10:49 AM
Default Re: ABS D series axles work in non ABS D? (dantastic)
thanks man now i know for sure i can use them
Old Feb 10, 2005 | 05:56 PM
92SiBlu's Avatar
thats whats on my hatch
Old Feb 10, 2005 | 05:58 PM
ABK's Avatar
ABK
yes they will if you need another vote, lol.
the only difference in the ring with all those teeth.
Old Feb 10, 2005 | 08:29 PM
Default Re: ABS D series axles work in non ABS D? (ABK)
thanks gusy really appreciate it
Old Feb 10, 2005 | 08:32 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">yes they will if you need another vote, lol.
the only difference in the ring with all those teeth.</TD></TR></TABLE>
Its called a tone ring, and yes, the ABS axles will work fine in a non abs car.
Old Feb 12, 2005 | 08:00 AM
urnotfast's Avatar
you can even knock the ring off of it if it bothers you. it just slips on the end of the axle, tap it with a hamer and it will come off.
Old Mar 7, 2005 | 07:19 AM
j0nptw's Avatar
Default Re: ABS D series axles work in non ABS D? (urnotfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urnotfast &raquo;</TD></TR><TR><TD CLASS="quote">you can even knock the ring off of it if it bothers you. it just slips on the end of the axle, tap it with a hamer and it will come off.
So if i have a 94' EX w/ ABS and i'm swappin in a GSR, i can buy non-ABS b series axles and take my tone ring off my d series axles and put it on the non-abs axles?
Old Mar 7, 2005 | 07:33 AM
Default Re: ABS D series axles work in non ABS D? (j0nptw)
I don't know if have the same size abs ring. Just get some abs gsr axles. They cost exactly the same as the non-abs axles at pep boys.
DARIUSZ - DNPhoto
Transmission & Drivetrain
Aug 22, 2009 01:06 PM
OOOtony
Mar 4, 2009 06:38 AM
Del Sol on Steroids
Aug 12, 2007 04:21 PM
arsenaldragster
Apr 24, 2005 10:49 PM
EKRacer
Mar 14, 2004 05:46 PM
