gsr swap into an ls
Old Feb 8, 2005 | 07:27 PM
jdmef-9's Avatar
Default gsr swap into an ls
ok so im putting a gsr motor into my dc4 and my main question is do i need a new throttle cable? and if i do couldn't i just use a skunk 2 and avoid having to change the cable?
Old Feb 8, 2005 | 08:32 PM
jdmef-9's Avatar
bump
Old Feb 8, 2005 | 10:33 PM
pubestripe's Avatar
Default Re: (jdmef-9)
well do u have the skunk 2 mani on the b18c1 now? or is it the dual stage on there? the cable will work with some manipulating, u should be fine, but an itr cable works better with the skunk 2 mani if u go that route...
Old Feb 8, 2005 | 11:22 PM
rovigian's Avatar
Default Re: (pubestripe)
Yes you will need a new throttle cable.
The skunk 2 or blox manifold is a good way to get around having to replace the cable, plus they have come down in price.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe &raquo;</TD></TR><TR><TD CLASS="quote">itr cable works better with the skunk 2 mani if u go that route...</TD></TR></TABLE>
Wait he has an LS. Aren't the LS and ITR throttle cables the same length?
Old Feb 9, 2005 | 08:49 AM
pubestripe's Avatar
Default Re: (rovigian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote">
Wait he has an LS. Aren't the LS and ITR throttle cables the same length?</TD></TR></TABLE>
i thought that the ls cable was a little shorter... hmmm i know they are close...
slowB20ej8
Mar 27, 2008 12:23 PM
ateggy1
Mar 17, 2008 09:27 PM
boomersz
16
Mar 10, 2007 08:08 PM
chimves
Mar 21, 2006 04:56 PM
GSRacer
Oct 9, 2001 04:53 AM
