Will this Tire size fits the GSR Blades rims? 205/60/15. Bridgestone Blizzack.
Now here is the difference - <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdc2gsr »</TD></TR><TR><TD CLASS="quote">235's on his 18x10s</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XyKo »</TD></TR><TR><TD CLASS="quote">GSR Blades rims?</TD></TR></TABLE>
You can't really go bigger then 205 and there isnt much room to go under 195.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Those tires are too big, 205/50/15s are what you are looking for if you want 205s.</TD></TR></TABLE>
yea thats what you want otherwise your tire and fender are gonna meet
wider isn't better when it comes to snow. blizzaks will give you better traction in snow, but not to the point to warrant 205's. the profile of the tire has a lot to do with traction in the snow as well.
You may be able to pull off 205/60s if your car isn't lowered at all. It's going to look ridiculous because they are about 1.5 inches taller and your tach is going to be off a bit.
On tirerack.com you can get them for like the same price and then you could get your exact tire size so I suggest shopping there. $70 isn't a real "deal".
With snow tires you want as narrow a tire as possible. Those will cut through snow and grip the road alot better than wider tires, which will tend to ride up over the snow more.
I would go so far as to say get some 185/60-15's, those would easily fit on a 6" wheel.
shoot, man. i've had all sorts of used crap tires on my car in the past. 205/60/15's? no freaking problem. handles bumps like a champ, no rubbing. don't sweat it. maybe it's not the best size for you and all, i'm just saying sure, it'll fit no prob. if you're not lowered, of course.
You mean 195/60/15s? Those will work fine. I have them on my integra and although they are a bit taller than stock, they don't rub on me and I'm dropped like 1.75 inches. I'd pick them up for $50/piece.
Guest
Posts: n/a
Guess, I'll back out. The tires he's selling are the older ones, blizzak ws-15. Thought it was ws-50. So, which is better for snow, found some at tirerack.
205/55/15
205/50/15
195/55/15
195/50/15
Would like to know asap, so I can put my order in.
These are going on my stock gsr blades.
205/55/15
205/50/15
195/55/15
195/50/15
dohc_hatchieback
20
Nov 18, 2003 09:06 AM
