Do u need Extra fuel when u p&p ur head on a LS??
Old Feb 8, 2005 | 07:09 PM
vtec25's Avatar
Default Do u need Extra fuel when u p&p ur head on a LS??
Ok i am running a kinda of a wild port and polished head on a LS(B18B) and 3 angle valve job also with i/h/e right now and i was told it is in need of extra fuel cuz its sucking in too much air cuz of the p&p and thats the reason why it is sluggish.
so my quetion is. is this true? and if it is can i just use a Adjustable Fuel Pressure Regulator? or do i need like a s-afc?
Old Feb 8, 2005 | 09:46 PM
Tuesday Club's Avatar
Default Re: Do u need Extra fuel when u p&p ur head on a LS?? (vtec25)
If the lack of fuel is the prob. get an AFPR and either s-afc or HONDATA.
Otherwise it could be another prob. ???
Old Feb 8, 2005 | 09:52 PM
hybrid_vtec's Avatar
Default Re: Do u need Extra fuel when u p&p ur head on a LS?? (mercuryfrost)
Well if you think of it, your head is now designed to flow large amounts of air through each engine revolution and the stock compression and cams can not move that much air. So now your motor is choking. Up the compression and get some cams to compliment your set-up!
Old Feb 9, 2005 | 10:40 AM
honda head's Avatar
how much over was the ports? cut are ypu runing a stock intake maifold and throttle body? maybe you should up grade your fuel system like pump, lines, rail, fpr,injectors to compensate for the increase of air volume.
Tong.Y
36
Dec 16, 2010 10:37 AM
kaj
Jan 21, 2006 12:07 PM
redvic
Jul 7, 2004 07:44 PM
94B18B1Teg
Jan 25, 2004 09:29 AM
94B18B1Teg
Jan 25, 2004 09:16 AM
