94rs inegra valve cover !! swap
Old Feb 8, 2005 | 06:48 PM
jspekdc2's Avatar
Default 94rs inegra valve cover !! swap
can i swap this valve cover into a 94 integra valve cover
Old Feb 8, 2005 | 06:56 PM
aznsins88's Avatar
i think it depends on wat motor you have. If you have an RS/LS/GS then i believe you can but if you have a GSR/Type-R then i dont think you can...correct me if im wrong im not 100% sure just my .02
~Eric
Old Feb 8, 2005 | 07:00 PM
jspekdc2's Avatar
Default Re: 94rs inegra valve cover !! swap (jspekdc2)
yeah i think so too cause i look at the valve cover n the bolts on it seem to be in the same place..
DarkDragon's Avatar
dont know if it means anything but thats the same valve cover my DA has, same place of bolts and everything. Im pretty sure it just depends on if it is VTEC or not, VTEC covers have diff middle bolt holes
Old Feb 8, 2005 | 07:07 PM
njandrewg's Avatar
Default Re: 94rs inegra valve cover !! swap (DarkDragon)
as long as its non vtec and is from OBD1 car you'll be fine
iH8RICERZ's Avatar
so you want to swith your new ls valve cover to the old ls valve cover? I believe the rs/gs/ls are all the same..and it should work...but you CANNOT use a Vtec valve cover on a non vtec head
Old Feb 8, 2005 | 07:08 PM
dirty_dan's Avatar
yes that valve cover will work. it is from a 96+ b18b1 or from a crv motor
one thing you have to do is either plug the hole on the valve cover that has the pcv valve coming out of it or you are going to have to redo your pvc system. i just plugged the hole in mine and everything runs good.
Old Feb 8, 2005 | 07:09 PM
jspekdc2's Avatar
Default Re: 94rs inegra valve cover !! swap (dirty_dan)
oh alrite koo thanks alot !
Old Feb 8, 2005 | 11:32 PM
rovigian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspekdc2 &raquo;</TD></TR><TR><TD CLASS="quote">oh alrite koo thanks alot ! </TD></TR></TABLE>
Yeah it works fine. If you want I have two in my house, and will sell one.
kiklo16
Jul 28, 2007 04:00 PM
Fezzie
Sep 3, 2006 03:05 PM
crxsteve
Aug 9, 2006 12:14 PM
JLange
Jul 29, 2003 03:23 AM
EKB18BPR3
Apr 26, 2003 02:29 PM
