Question on bending
Old Feb 8, 2005 | 06:20 PM
number7s's Avatar
Default Question on bending
ok, i got a bender, but its a manuel one, should i heat the pipe while i bend it or does anyone have some tips on that
Old Feb 8, 2005 | 06:32 PM
Canuk_SiR's Avatar
Default Re: Question on bending (number7s)
depends how thick it is. if its very thick, heat is always good, but I wouldnt heat anything under 1/2" wall. and since you've got a manual bender, I doubt you'll ever see anything that thich with it
one trick that we sometimes use at work, is to fill the pipe with sand, tack some caps on it so the sand stays put, and bend your pipe. the sand keeps the pipe from getting crushed, and you come out with a nicely bent pipe almost all the time.
Old Feb 8, 2005 | 06:52 PM
number7s's Avatar
k, i think it is like 3/8 in, thanx for the sand tip
hmtcrxsir
Apr 26, 2010 08:23 PM
TurboSI56
Welding / Fabrication
Aug 12, 2006 08:40 AM
r0yal
Apr 19, 2006 07:03 PM
FURACERMAN
Jan 6, 2006 06:32 PM
