my turning signal is messed up..help. blink 2x faster
Old Feb 8, 2005 | 06:12 PM
97civic123's Avatar
Default my turning signal is messed up..help. blink 2x faster
I just replaced my headlights, and replaced my clear turning signal with yellow ones. well my front driver, isn't blinking. my rear driver, is blinking twice as fast. the passenger front and rear seems to blink at the normal rate, but the front seems loose. when i shake it alittle it turns on and off. any help?
Old Feb 8, 2005 | 06:16 PM
PUSHER's Avatar
Default Re: my turning signal is messed up..help. blink 2x faster (97civic123)
Dunno if this is any help as its hard to understand what your asking. But if a front left bulb is dead or not working/hooked up then the back left bulb will blink twice as fast.
Confucius37's Avatar
something is wrong with your front driver's side bulb, check out the connections on it and also on the front passenger since it seems loose. If the relay is still working and it starts to blink twice as fast, all the power goes to the rear and makes it blink twice as fast.
Old Feb 8, 2005 | 06:18 PM
97civic123's Avatar
the front left turns on,it's just when i put the turning signal it blinks fast....
Old Feb 8, 2005 | 06:21 PM
Lmgrcivic's Avatar
then change the bulb maybe only part of the balb burnt out if that doesnt work check your wiring to the plug
Old Feb 8, 2005 | 06:25 PM
97civic123's Avatar
Default Re: my turning signal is messed up..help. blink 2x faster (Lmgrcivic)
k.. thanks guys. i'll check it out.
Old Feb 9, 2005 | 03:17 PM
97civic123's Avatar
i just checked today guys. there's nothing wrong with the bulb. i even replaced it with a new one, and still the same problem with the fast turning blinking, and the front left won't blink.
Old Feb 9, 2005 | 03:26 PM
Officer's Avatar
I had a similar problem on my hatch and what it came down to was that, there was a short in the stock wiring. maybe that helps...sorry
Old Feb 9, 2005 | 03:37 PM
97civic123's Avatar
Default Re: my turning signal is messed up..help. blink 2x faster (TotaledHatch)
it was fine before until i changed the turning signal bulb....could it be a fuse somewhere?
Old Feb 9, 2005 | 05:29 PM
97civic123's Avatar
anyone?
Old Feb 9, 2005 | 05:33 PM
parasonic's Avatar
Heh, I've had the same problem before. In a Ford Expedition. The thing still worked. I don't know what was wrong. If it had been a short, something would have blown or just not worked IMO. Try replacing your flasher "relay" if it bothers you that much.
Old Feb 9, 2005 | 05:37 PM
menkio's Avatar
Default Re: my turning signal is messed up..help. blink 2x faster (parasonic)
reset your ecu
Old Feb 9, 2005 | 06:09 PM
hctjohnson's Avatar
you probably need a dual filament bulb, a short is also likley
Old Feb 9, 2005 | 07:18 PM
2000DX's Avatar
Default Re: my turning signal is messed up..help. blink 2x faster (hctjohnson)
Check the metal thing at the bottom of the connector where you put the bulb in. The metal piece might not be sticking up high enough.
Old Feb 9, 2005 | 07:28 PM
Atheist's Avatar
You could check the fuse in the engine bay, but I would put the old back in. Are you SURE you are putting in the right bulb? Clean the socket.
Old Feb 9, 2005 | 07:45 PM
97civic123's Avatar
Default Re: (Atheist)
i did try using the old one again, and it's still the same problem.
Old Feb 9, 2005 | 07:46 PM
2000DX's Avatar
Default Re: (97civic123)
did u check the metal thing at the bottom of the connector? it might help, it worked for me before.
Old Feb 9, 2005 | 07:59 PM
97civic123's Avatar
Default Re: (2000DX)
not yet, i'll do that next. are there any other suggestions?
Old Feb 9, 2005 | 08:02 PM
Lord Helmet's Avatar
Dam all these post and not one of you guys got it right so far LOL.
Here's my answer and I'm quite sure of it. There's a semi clear box that has alot of wires going into it inside the engine bay. When you pop open the engine bay look at the where the headlight and corner lens meet at near the rear. On the side of the fender wall is that semi clear box with alot of wires going into it. That is a chassis ground, that is what causing your front blinker to not work right and the rear to blink faster then necessary. Usually it's mounted with a bolt, if it's loose then that will cause the blinkers to go crazy.
BTW both sides have these chassis grounds
Old Feb 10, 2005 | 06:24 AM
97civic123's Avatar
Default Re: (sleeperciv)
is this box on the driver side, or the passenger side? what engine component is next to?
Old Feb 10, 2005 | 06:58 AM
eg6nes's Avatar
Check if the bulb is two prong or singel prong it was two on my 93 civic if that is not the problem take out that light strip back the wier cover and make shure all the wiers are connected. Turn signals blink faster to let you know that one is out.
Old Feb 10, 2005 | 10:07 AM
97civic123's Avatar
Default Re: my turning signal is messed up..help. blink 2x faster (primed)
problem solved. 2000DX was right. it was just the bottom of the connector inside the socket. i just pryed it out alittle, and everything went working fine.
Old Feb 10, 2005 | 11:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civic123 &raquo;</TD></TR><TR><TD CLASS="quote">problem solved. 2000DX was right. it was just the bottom of the connector inside the socket. i just pryed it out alittle, and everything went working fine.</TD></TR></TABLE>
lol go figure
Old Feb 10, 2005 | 05:59 PM
DOHC_VTEC69's Avatar
Default Re: my turning signal is messed up..help. blink 2x faster (menkio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio &raquo;</TD></TR><TR><TD CLASS="quote">reset your ecu </TD></TR></TABLE>
its in the bulb, buy a single element bulb and a double element bulb and try them both
one will fix your problem
i had the same problem but i cant remember which element fixed it,(single or double)
Old Feb 10, 2005 | 06:12 PM
MonkeyMagic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">Dam all these post and not one of you guys got it right so far LOL.
LOL and neither did you!
i have seen the dumbest automotive threads and the dumbest answers on h-t lately.. 05 is lookin bleak
