I noticed something today......
Old Feb 8, 2005 | 06:02 PM
groundedcivic91's Avatar
Default I noticed something today......
While driving at constant speed, 25, 35,45 or so, doesn't matter what gear I am in, all of a sudden the car will decelerate slightly, it feels like i just lifted my foot off the pedal a tiny tiny bit, like to slow down from 35-30 or something. BUT infact, foot is in same position. I have been noticing this more and more recently.
Whats up?
Old Feb 8, 2005 | 06:05 PM
untitled's Avatar
Default Re: I noticed something today...... (groundedcivic91)
hmmm. Hard to diagnose over the int3rw3b.
hrm..
Does your idle fluctuate? Does the rpms fluctuate when you try to hold the revs at a certain rpm when in neutral?
Old Feb 8, 2005 | 06:14 PM
Default Re: I noticed something today...... (untitled)
No, nothing like that. Revs stay constant while in neutral and foot on the pedal. No CEL's either.
I am thinking TPS perhaps or an elctrical problem.
EDIT: idle dies out to where car stalls if it is REAL cold out, and its the first time its started, but after 2 mins, even with engine temp below "C" the car will idle fine and not stall, its just that first minute or so.
Modified by groundedcivic91 at 3:29 AM 2/9/2005
Old Feb 8, 2005 | 06:25 PM
untitled's Avatar
i have no clue what to tell you, TPS maybe, map sensor could have trouble seeing manifold pressure, could be a multitude of things.
Old Feb 8, 2005 | 06:29 PM
O come on, you dont have the mAd tyt3 intAweB skillzzz y0
Old Feb 8, 2005 | 06:30 PM
AnarkyPhreek's Avatar
man, i hear ya- mine has the same problem- but mines worse as soon as i start mine it sticks up at 2000 rpm and slowly comes down as the car heats up- then for like the next few minutes the car wont catch idle it will just shut off when i engage the clutch and it drops to idle.. its crazy- am i correct in thinking theres a air/ fuel problem- it also backfires sometimes.. could the injectors be clogged ? or could i have a engine code or something thats making it run lean?
Old Feb 8, 2005 | 06:31 PM
kim_2_da_chee's Avatar
I have that same problem.
I'm thinkin that it might be my pressure plate.. but I also think that it's electrical. I have no CEL's either... no codes.
I don't have the money to start replacing "suspect - parts"... so I'm just dealing with this minor problem for now.
Here's how I'd describe my problem:
In any gear, usually around 2500-3500 rpm, when on the throttle slightly in cruising speeds... my motor seems to "sputter" like it's bogging or something.
Old Feb 8, 2005 | 06:33 PM
untitled's Avatar
Default Re: (AnarkyPhreek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnarkyPhreek &raquo;</TD></TR><TR><TD CLASS="quote">man, i hear ya- mine has the same problem- but mines worse as soon as i start mine it sticks up at 2000 rpm and slowly comes down as the car heats up- then for like the next few minutes the car wont catch idle it will just shut off when i engage the clutch and it drops to idle.. its crazy- am i correct in thinking theres a air/ fuel problem- it also backfires sometimes.. could the injectors be clogged ? or could i have a engine code or something thats making it run lean?</TD></TR></TABLE>
MAP sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee &raquo;</TD></TR><TR><TD CLASS="quote">I have that same problem.
In any gear, usually around 2500-3500 rpm, when on the throttle slightly in cruising speeds... my motor seems to "sputter" like it's bogging or something. </TD></TR></TABLE>
Injectors or MAP sensor.
Old Feb 8, 2005 | 06:34 PM
CRX_1.8T's Avatar
I while back, my B18 would throw a MAP sensor code if I held it at like 2700 or so for a couple minutes. What was weird is that it would only do it sometimes (like once every few weeks) and all I would have to do is turn the key off and then turn it back on; the CEL wouldn't appear again for weeks. As of now, it hasn't shown for a couple months.
I have no idea why it did this either. But I know when the MAP sensor did make then engine light come on, there wasn't any loss of power that I could notice. Not saying it would be the same for you. Luckily it kind of just corrected itself LOL
Old Feb 8, 2005 | 06:43 PM
Default Re: I noticed something today...... (CRX_1.8T)
correct me if I am wrong, no map = no vtec.....this may not suit you, but me, it does, since i have sohc vtec motor.
Eitherway, no map code here what so ever, no CEL's period. I have a VAFC2 to monitor the MAP and TPS voltages and i can't ever find anyone to fill me in on what they should be WHILE the car is running
Old Feb 8, 2005 | 06:45 PM
CRX_1.8T's Avatar
Do you have access to a Helm's manual?
Old Feb 8, 2005 | 06:46 PM
untitled's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by groundedcivic91 &raquo;</TD></TR><TR><TD CLASS="quote">correct me if I am wrong, no map = no vtec.....this may not suit you, but me, it does, since i have sohc vtec motor.
Eitherway, no map code here what so ever, no CEL's period. I have a VAFC2 to monitor the MAP and TPS voltages and i can't ever find anyone to fill me in on what they should be WHILE the car is running</TD></TR></TABLE>
Are you connections to the SAFC soldered in, or are they butt connected together, you may be losing a slight amount of voltage.
Your map sensor will not throw a code unless it sees 0 vacuum when the car is running and the throttle isnt WOT. I seriously think this is a map sensor problem.
Old Feb 8, 2005 | 07:09 PM
O yes, VAFC connections are ALL soldered in. I know all about what doing it with crimp connectors can do.....TROUBLE!!!!!!
Well, as simple as MAP sensor is to replace, perhaps I will try to find one for CHEAP online, ebay, or something.
CRX_1.8T....I have a Haynes...no Helms thou
Old Feb 8, 2005 | 07:14 PM
CRX_1.8T's Avatar
You may want to try the local yards around you, I know that I see a shitload of wrecked Civics all over the place (gotta love women drivers LOL), I'm not sure what the pricing would be. Just go to the yard in a non-Honda vehicle and when you go to the counter, ask them how much it is for "this Ford Fiesta sensor" or something.
I have seen some yards who charge more for Honda stuff (?!) so that is what I do. It seems to have worked for me since I have been doing it.
bigpunn421
Mar 21, 2012 03:14 PM
4tika4
Apr 19, 2009 09:43 AM
Concept Tuning
Apr 28, 2006 08:28 PM
T-Mo
11
Sep 28, 2003 10:17 AM
stRtypR25
Jan 12, 2003 03:09 PM
