how to make car run smoother?
Old Feb 8, 2005 | 05:50 PM
tca0bell's Avatar
Default how to make car run smoother?
i just hit 190k with my 94 ex ej1. it runs kind of loud and isnt very smooth when it runs or idles. what can i do to make it run smoother and not shake so much?
Old Feb 8, 2005 | 05:53 PM
jlacoy82's Avatar
71.192.16.183
Default Re: how to make car run smoother? (tca0bell)
Tune-up, and adjust the valve lash.
Do a search on "tune-up" and "valve adjustment" in the "Archived Content" in this forum.
Here ya go:
https://honda-tech.com/zerosearch
You'll literally find 10x more info than you can actually comprehend.
hawaiianbro's Avatar
Well when was the last time you changed the cap, rotor, spark plugs, and spark plug wires? You could also move from a 5W-30 oil to a 10W-30 oil. I personally stay with 5W-30 oil and substitute with 1 quart of Lucas Oil Stabilizer....It keeps the 'knocking' and makes my engine run a lot smoother. But just get a tune up or replace all those items i stated up top!
Old Feb 8, 2005 | 05:57 PM
GTlvr82's Avatar
Default Re: how to make car run smoother? (hawaiianbro)
Sounds stupid but replace the PCV valve too....and get your intake mani hot tanked and clean out your throttle body and IACV.....
Old Feb 8, 2005 | 06:04 PM
tca0bell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawaiianbro &raquo;</TD></TR><TR><TD CLASS="quote">Well when was the last time you changed the cap, rotor, spark plugs, and spark plug wires? You could also move from a 5W-30 oil to a 10W-30 oil. I personally stay with 5W-30 oil and substitute with 1 quart of Lucas Oil Stabilizer....It keeps the 'knocking' and makes my engine run a lot smoother. But just get a tune up or replace all those items i stated up top!</TD></TR></TABLE>
How much would it cost to change the cap and rotor? i read a lot about that but im not sure if i can do it myself. ill probaly change my spark plugs and wires. which ones are good? i switched to vavoline 5w-30 high milege oil like last year and recently i used the valvoline maxlife engine protector thing that is like 4 bucks at walmart. it ran a little smoother for a little but its the same after a few days.
Old Feb 8, 2005 | 06:06 PM
jlacoy82's Avatar
71.192.16.183
You can get a cap + rotor from the sponsor section here on H-T for less than $20 shipped.
I did my first cap and rotor last week on my y8, took me all of 30 minutes. Its an incredibly simple process.
Old Feb 9, 2005 | 02:48 PM
skip122's Avatar
Default Re: how to make car run smoother? (jlacoy82)
tune up valve job timing belt waterpump
Old Feb 9, 2005 | 03:35 PM
civicboisi's Avatar
Default Re: how to make car run smoother? (skip122)
some would suggest seafoam...but then again your motors got a few miles on it...some people have done it with no probs with even more miles, but who's to know
Old Feb 9, 2005 | 04:47 PM
GUNNER666's Avatar
willyou notice a differancewith a new rotor and cap, along with new spark plugs and wires? if so how much. i've been thinking of doing this but keep stalling!
Old Feb 9, 2005 | 05:25 PM
jayare05's Avatar
Default Re: how to make car run smoother? (GUNNER666)
how does everyone feel bout replacing one quart of oil with that oil stabilizer? ive used it for about 4 months on a previous car, but ive heard that thats no good for a motor
Old Feb 9, 2005 | 05:29 PM
numbnuts22715's Avatar
Ive heard that its not good too, but I know it worked wonders on my car... I had a really really rough idle, and after using Lucas oil stabilizer, it smoothed out a whole lot... But I dunno... If I were you Id read up on it some more to see the pros and cons on it, if it messes up my motor I dont really care sinceIm swapping it in about 3 1/2 months...
Old Feb 9, 2005 | 05:32 PM
jayare05's Avatar
Default Re: (numbnuts22715)
yeah good idea.
Old Feb 9, 2005 | 06:13 PM
hctjohnson's Avatar
nobody mentioned a fuel filter
Old Feb 9, 2005 | 06:16 PM
tca0bell's Avatar
Default Re: how to make car run smoother? (hctjohnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hctjohnson &raquo;</TD></TR><TR><TD CLASS="quote">nobody mentioned a fuel filter</TD></TR></TABLE>
im kinda scared to do that since i've read a lot of people have had problems changing it and its a B. since i got the car i've always pumped chevron with techron or shell v power so it should be clean right?
Old Feb 9, 2005 | 06:18 PM
CRXDrew's Avatar
A tune up once and a while will is great for making you realize how nice it is to have a high mileage Honda
cap
rotor
wires
plugs
change coolant
change oil- 10w30 for me
oil filter of course
fuel filter
valve adjustment
PCV valve
reset ECU
air filter
And then give the engine bay a nice cleaning, that won't help with performance, but a clean engine is a slightly happier one.
Old Feb 9, 2005 | 06:37 PM
hctjohnson's Avatar
190k=way past fuel filter replacement, crxdrew summed it all up
1992honda
Jul 26, 2011 05:42 PM
Sardawg
Apr 17, 2006 06:48 PM
cd5_2NR
Nov 26, 2005 05:52 AM
dc2integra
Dec 27, 2004 06:29 AM
gooberwolf
Sep 21, 2003 05:17 PM
