code 15?! i checked it via the helms way and still have nothing!
ok CEL is coding for a 15 i checked it via the helms way, i tested the wires at the distro, tested the wires at the ecu, tested the distro, replaced it with a known working one, and i still have a Code 15?!?!?! WTF!!!!!! i was thinking of just hardwiring the distro the ecu does anyone know how to do this? which 2 wires go where? i know the black/yellow one is connnected to the ignition somewhere but what about the blue wire where does that connect too? any input/help would be apperiated!
Are you getting any other codes? I was getting a code 15 and 17 because my speedometer cable was unplugged. I replaced my cable and now no more CELs. Maybe you have another code and you computer is just picking up the other one for some reason.
omg i am having the same exact problem just started the other day, i changed my coil nothing, changed the ignitor, nothing so i bought a new one and still nothing so if i find the answer i will let you know, the wierd part about the whole thing is i am getting a little spark. so if you find out pm me if i find out i will post it and pm you
code 15 just poped up on mine along with 22 and 7 but i know how to fix those 2 just code 15 is bugging the **** out of me. when i get to around 6800 rpm that when it starts. do you have the same thing going on or does the cel light come on as soon as you start the car? ill let you know if i find any thing tomarrow becaue ill be working on it all day.
I just had this happend 3days ago on a freinds car (89' civic D15) I replaced the TPS and it stopped throwing the cell. try that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloS13 »</TD></TR><TR><TD CLASS="quote">
Vtec Air Flow Converter
Throttle Position Sensor
If somebody says 'Air/Fuel computer, i will smack them!'</TD></TR></TABLE>
i agree its more like trick and treat
to the stock rom
to the stock rom
hans stoner
Oct 22, 2006 07:13 AM
