Broken front tranny mount on GSR swap, Can i just not use it?
Old Feb 8, 2005 | 04:41 PM
97civicdx's Avatar
Default Broken front tranny mount on GSR swap, Can i just not use it?
Front tranny torque mount is broken, can i just forgo it and rely on the 3 main and a/c mounts?
Old Feb 8, 2005 | 06:12 PM
Finger Lickin' good's Avatar
Default Re: Broken front tranny mount on GSR swap, Can i just not use it? (97civicdx)
eww tough call. I would say you can, but dont think over time there wont be any side effects from it. otherwords, if its a beater, dont bother.
Old Feb 8, 2005 | 11:37 PM
rovigian's Avatar
As long as the tranny upper mount is fine, you are good to go. The upper three mounts are the important ones.
Old Feb 8, 2005 | 11:42 PM
robboostgsr's Avatar
yea your fine. same thing happened to my friend 3 years ago.he is still driving the car.
Old Feb 9, 2005 | 01:15 AM
97civicdx's Avatar
Default Re: (robboostgsr)
Thanks guys. I am going to use main mount inserts to stiffen the three main mounts up.
Old Feb 9, 2005 | 04:22 AM
furious94ls's Avatar
Default Re: (97civicdx)
If Honda thought it was safe to run on 4 mounts, they would have only used 4. Buy the new mount.
Old Feb 9, 2005 | 07:28 AM
95lstegman's Avatar
Default Re: (furious94ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by furious94ls &raquo;</TD></TR><TR><TD CLASS="quote">If Honda thought it was safe to run on 4 mounts, they would have only used 4. Buy the new mount. </TD></TR></TABLE>
normally i agree, go with honda's engineering. however, you could just "junkyard dog" this one and save a bunch, and still have the legendary Honda engineering on your side.
Old Feb 9, 2005 | 10:29 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys. I am going to use main mount inserts to stiffen the three main mounts up.</TD></TR></TABLE>
this sounds fine to me. i am running hasports right now and i only have the 3 main mounts hooked up. ive had more than a few 5k+ rpm clutch drops with my 6 puck and not a damn thing has happend. the most important mount on your car is the rear trans (torque) mount. the upper tranny and drivers sides are called torsion mounts(prevent the motor from twisting) and the other 2 are just added weight you dont need
Ex-Eg-Driver
Feb 26, 2008 05:35 PM
97civicdx
Feb 9, 2005 12:32 PM
T--Rex
17
Dec 11, 2004 11:18 PM
yaya
Mar 19, 2004 01:46 PM
Skyllz
Sep 13, 2003 11:45 AM
