carbing 3 pt install tip
Old Feb 8, 2005 | 04:38 PM
an2ny888's Avatar
Default carbing 3 pt install tip
just got my rigid ( carbing copy ) bar , front (3 pt) and rear for $180 used , and it appears that you can reverse the orientation of the brake reservoir so that you can open the cap with the bar on. not sure about this though, am going to try it later
Old Feb 8, 2005 | 05:23 PM
130R's Avatar
Default Re: carbing 3 pt install tip (an2ny888)
rigid and carbing are made by the same manufacturer
carbing'ed: who has carbing gets rigid also
Old Feb 8, 2005 | 07:37 PM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
where can u get these bars? any links guys? thanks
Old Feb 8, 2005 | 07:44 PM
DC231 Sean's Avatar
Default Re: carbing 3 pt install tip (01ITR#173DC2ning)
Visit http://www.aj-racing.com
Old Feb 8, 2005 | 08:16 PM
8k-red-DC2's Avatar
Tell me you really got both bars for 180 bucks...man, ill give you 190 for them, jealous as hell.
Lets see pics. This thread sucks w/o pics and a "FS: rigid bars" offer
Old Feb 8, 2005 | 10:03 PM
thanks for the link
Old Feb 12, 2005 | 11:25 AM
Circuit Star-29's Avatar
As far as I knew, these bars won't fit ITRs because of the res. Please explain.
Old Feb 12, 2005 | 06:26 PM
an2ny888's Avatar
Default Re: carbing 3 pt install tip (C-speed Racing)
itr reservoirs can be flipped, meaning you install it with the cap side nearer to the booster, instead of the stock configuration where the cap is further away from the booster. its simple, drain your reservoir, remove it then flip it, fill it up with brake fluid and you're all set, no need to even bleed the brakes. i just did this on my car, the 3 pt bar fits perfect, AND i still have full access to my brake reservoir
Old Feb 12, 2005 | 06:33 PM
Black R's Avatar
25 Year Member
me = no understand without pics.
Old Feb 12, 2005 | 07:01 PM
migs's Avatar
Default Re: (Black R)
Detach the reservoir and turn it around. See how the reservoir cap gets in the way? If you flip it, it will sit closer towards the booster.
ic3pham
Sep 10, 2008 08:28 PM
fcfromhell420
Sep 14, 2007 11:21 PM
mnneon
Welding / Fabrication
Jan 13, 2006 09:10 AM
HotShotMedic
16
Jun 16, 2005 05:45 PM
Willard
Jun 23, 2001 07:34 PM
