Zex Nitrous Kit Questions...
I'm getting a Zex Kit in a couple of days and just have a few questions about it.
I've heard some people say you need to warm the bottle before u can spray...is that right, does the bottle have to be around 98 degrees to spray? If I were to spray and it was colder, what would happen...do you suggest buying a bottle heater, or what?
Lastly, I was first told to run a 65 shot that I just needed to retard the timing on my cam gear 3 degrees...now I'm being told that I need to adjust the ignition timing...which one is correct, or do I have to do both?
[Modified by newsense, 3:35 PM 1/16/2002]
Ok, so I don't need to retard the cam gear 3 degrees, correct??
How would I go about retarding the ignition timing a couple degrees?
here are some instructions in case youve never done it:
http://www.c-speedracing.com/howto/timing/timing.html
man...i'd buy a msd digital 6 asap. riding with your timing retarded a few degrees when not spraying is gonna make your car lag and run like ****.
[Modified by delacampos, 10:38 PM 1/16/2002]
dont even bother changing the timing with 65 shot . if you do it on the dist , you will lose when not spraying
either get a dig 6 or dont even do it . . . your not spraying enough to have to reatard it . .
and the bottle warmer will be your best mod you can get with nitrous. i am living proof.
Does anyone have a complete explanation of how to change the timing? Or maybe a site that tells you how...
