Timing Belt Question
Old Jan 16, 2002 | 11:00 AM
Low_bias's Avatar
Default Timing Belt Question
I have a 98 LX with the VTEC 4.
I'm in the low 80k mileage range, so it is time to start thinking about changing the old timing belt. Has anybody ever done this themselves? If so, how hard is it to do (I have limited experience)?
Also, do you recommend changing anything else while it is all opened up? Things like balance shaft belt, water pump, belt tensioner spring, main seal, etc.?
Thanks in advance
-Low_bias
Old Jan 17, 2002 | 06:06 AM
Gennady's Avatar
New User
Default Re: Timing Belt Question (Low_bias)
If you have limited experience, I dont think you should try. With a timing belt, you usually change the water pump, and if you want to change your cam or cam sprocket, that is when you do it also.
Old Jan 17, 2002 | 08:42 AM
urbanlegend21's Avatar
New User
Default Re: Timing Belt Question (Wont be beat)
it requires your side motor mount removal and requires two belts, timing belt and timing balancer belt
if you are familiar with mechanics and have a large amount of time to do the work I would say take a stab at it but Wont Be Beat is right, it is pretty complicated and hard
you have to time the oil pump, crank, and timing belt drive pulley to specs also
Old Jan 17, 2002 | 12:55 PM
Low_bias's Avatar
Default Re: Timing Belt Question (urbanlegend21)
Thanks for the replies, guys.
I'll change the water pump. What about the tensioner, main seal, or balance shaft belt?
Also, why would you change the sprocket? I wouldn't think it would get much wear since it only touches a rubber belt. And changing the cams...were you referring to a higher performance cam? 'Cause at only 81k I would think it still has a lot of life left in it. This car is nothing special...just my wifes daily driver.
Thanks
-Low
Old Jan 17, 2002 | 01:00 PM
New User
i would take the time and inspect those things but they don't have to be replaced at the same time
i wouldn't change the cam or cam gear unless you were going for some performance, cams don't wear to the point of replacement through the life of the motor unless run without oil
Old Jan 18, 2002 | 03:19 AM
New User
ttt, so the actual technical questions don't get lost
Old Jan 18, 2002 | 05:59 AM
Gennady's Avatar
New User
I suggested the cam and cam sprocket because I am getting a stage 1 cam and performance sprocket and when I called up some shops, they suggested changing the timing belt at the same time.
Remind me again, what ttt means?
Old Jan 18, 2002 | 06:09 AM
New User
to the top
Old Jan 19, 2002 | 02:21 PM
John's Avatar
New User
to the top
Morgan, you seem to be the enforcement element lately... making sure all the technical questions stay on the top... good job officer...
Old Jan 20, 2002 | 07:59 AM
New User
Default Re: Timing Belt Question (DunReit)
i catch alot of flak to when my answers are a little off, but no one else takes the time to revive these things when they get pushed to the bottom of the list
dj-t
Feb 20, 2012 07:13 PM
whiteboy-dc4
Feb 3, 2010 11:52 AM
chahsiubow
Dec 14, 2007 10:01 PM
honda94accord
Apr 10, 2007 05:39 AM
