bypass valve on cold air intake
Old Feb 8, 2005 | 02:55 PM
bigpoppa15's Avatar
Default bypass valve on cold air intake
does it matter if my intake is a solid pipe, without the bypass valve, or should i cut it and get a bypass valve?
Old Feb 8, 2005 | 03:22 PM
00MugenLude's Avatar
Default Re: bypass valve on cold air intake (bigpoppa15)
Just avoid deep water. 8" or more.
Old Feb 8, 2005 | 03:25 PM
prelude1897's Avatar
you should be okay. I've driven through the rain with my CAI a few times, but I drive in a low gear just to keep the rpms high
Old Feb 8, 2005 | 05:29 PM
tge39's Avatar
Most people will say that you don't need the bypass valve and in some certain cases you don't but if i where you i would get it to be safe. I do know that it works if you are in SMALL puddles of water, if you get submerged it aight nothing you can do. Add it for safety!!!!
Old Feb 8, 2005 | 05:50 PM
The Phil's Avatar
Default Re: bypass valve on cold air intake (tge39)
actually, if i remember right...the bypass valve only works when the filter is completely submerged. So it wouldnt work in small puddles, but would work if you're submerged.
either way, i'd get it just for safety.
Old Feb 8, 2005 | 05:54 PM
hOndafienD 04's Avatar
Default Re: bypass valve on cold air intake (xthephilx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">actually, if i remember right...the bypass valve only works when the filter is completely submerged. So it wouldnt work in small puddles, but would work if you're submerged.
either way, i'd get it just for safety.</TD></TR></TABLE>
yeah bypass valve is a waiste of money imo
when i go threw puddles i step on the clutch no matter wat gear im in and let it idle as im going threw.
Old Feb 8, 2005 | 06:02 PM
The Phil's Avatar
Default Re: bypass valve on cold air intake (hOndafienD 04)
or just get a SRI
Old Feb 8, 2005 | 06:29 PM
yeah if your scared of puddles thats your safest way
5200BB6's Avatar
you dont need it cause it dont work unless your in a flood, but why would you drive your car in a flood?
Old Feb 8, 2005 | 06:32 PM
The Phil's Avatar
Default Re: bypass valve on cold air intake (5200BB6)
thats what i was saying. thats why i got a SRI instead of a CAI
Old Feb 8, 2005 | 06:40 PM
KB96VTEC's Avatar
dont get it unless you live in an area that floods. if you drive hard it will eventually crack from the engine torqueing back and you lose an HP or two anyway.
Old Feb 8, 2005 | 06:56 PM
get some inserts and you wont have that torqueing problem.
Old Feb 8, 2005 | 07:00 PM
super-lude-31516's Avatar
i would def. get the valve.
a friend of mine decided to not get a valve and hit a puddle the next week...he has a new motor now
Old Feb 8, 2005 | 07:03 PM
valve wouldnt have helped him unless his intake was completely in water...we covered this up top already...
Old Feb 9, 2005 | 01:24 PM
bigpoppa15's Avatar
thanx for the help guys!
Old Feb 9, 2005 | 11:18 PM
hothotpete's Avatar
i have CAI and i cut a hole in my bumper to let in more air. i'm getting a air duct to replace where i cut, and it's a much larger hole. my area doesnt flood or anything, but we do get crazy snow in the winter. you think i should get a bypass valve? if so, what size? i measured my CAI and the circumfrence is 7". i did the formula and according to math laws, the diameter SHOULD be 2.25". i have a b18b....what size is that? i searched, but nothing. LMK your opinions
Old Feb 10, 2005 | 12:27 AM
revlimitx04's Avatar
Default Re: bypass valve on cold air intake (ferio pete)
Wait.. im confused.. Preludes = very low cars.
Why the hell would you be driving in 8" or more of water in a prelude... in TX we get floods all the time.. Thats why i have a truck.
Note to everyone: Dont drive your prelude in a lake.
Waste of money. all show no go.
Besides to put it to use, your car probably would be stuck at that point and drifting around like a dead fish.
ricetoniceeg
Dec 21, 2004 07:05 PM
B18Redline
May 3, 2002 01:15 PM
Acc91ord
Feb 26, 2002 10:27 AM
infinkc
17
Dec 2, 2001 02:40 AM
iCcharliee
Nov 27, 2001 07:46 PM
