radiator fan only works sometimes!
Old Feb 8, 2005 | 02:28 PM
LagunaSecaEG's Avatar
Default radiator fan only works sometimes!
just recently ive noticed that my car has been overheating on my way home from work which is about 15 miles away. Ive changed my thermostat and it was still overheating. Then when my car is all the way hot that the fan doesnt work at all, but sometimes it does its really weird. I have a fluidyne radiator and a local auto parts slim fan. also i changed the water pump about 10,000 miles ago. Any ideas?
Old Feb 8, 2005 | 02:30 PM
dantastic's Avatar
Default Re: radiator fan only works sometimes! (LagunaSecaEG)
slim fan not pushing/pulling enough air? did u bleed your cooling system properly?
Old Feb 8, 2005 | 02:34 PM
jlacoy82's Avatar
71.192.16.183
Default Re: radiator fan only works sometimes! (dantastic)
Is the fan physicall not coming on/turning, or does it just suck at..........sucking?
If its just intermittently coming on, check the wiring.
Old Feb 8, 2005 | 02:44 PM
screech's Avatar
the fan relay may be takin a crap on you
Old Feb 9, 2005 | 12:54 PM
Default Re: radiator fan only works sometimes! (screech)
the fan sometimes comes on and sometimes it doesnt. I rigged it up and took my relay out and use a paper clip and it blows all the time. it worked fine before that.
darin108
Aug 8, 2014 05:46 AM
EGed up from the seat up
18
Jun 1, 2011 02:16 AM
91EF919
Apr 4, 2009 12:12 PM
EF8 JUNKIE9
15
Aug 27, 2005 08:35 PM
