ACT CLUTCH QUESTION
Old Jan 16, 2002 | 10:39 AM
MUGENTYPER's Avatar
Default ACT CLUTCH QUESTION
wassup people!! im in a process to order a ACT clutch right now just wanted to know if i need the 6 puck disc or 4 puck disc i should buy... i have NOS installed on my car and just wanna make sure if u guys r using the same.. please give me some info about what you guys are using!! thanks
Old Jan 16, 2002 | 10:47 AM
sgT's Avatar
sgT
Default Re: ACT CLUTCH QUESTION (MUGENTYPER)
depends on how you like your engagement.
I recommend either the full face or 4 puck as the 6 puck chatters way too much.
Old Jan 16, 2002 | 10:51 AM
MUGENTYPER's Avatar
Default Re: ACT CLUTCH QUESTION (sgT)
is this still street drivable??
Old Jan 16, 2002 | 10:54 AM
sgT's Avatar
sgT
yes, but that depends on you
Old Jan 16, 2002 | 10:57 AM
MUGENTYPER's Avatar
what do u mean?
Old Jan 16, 2002 | 11:13 AM
sgT's Avatar
sgT
how much you care to deal with.
4 puck engagement is a bit harsh and takes some getting used to.
full face engages like stock.
Old Jan 16, 2002 | 11:20 AM
mafay2's Avatar
New User
I have the full face and I would highly recommend it for street use. I think unless you are running high horsepower and don't drive your car on the street, the full face one is good enough for you.
Old Jan 16, 2002 | 11:34 AM
MUGENTYPER's Avatar
Default Re: ACT CLUTCH QUESTION (mafay2)
full face?? need more info about this
Old Jan 16, 2002 | 11:37 AM
sgT's Avatar
sgT
full face = stock
act also sells one though
Old Jan 16, 2002 | 12:28 PM
mingchi96
Guest
Posts: n/a
you can go with clutchnet. I have a brand new clutchnet 6 puck with sprung hubs and a DUAL diaphgram pressure plate. I was going to put it in my car.. but got tired of waiting.. so I put in my ACT street strip clutch. I had this clutch in my car and it grabs like a biatch. it also engages quite hard, but still very streetable because of the sprung hubs. If you are interested in this Im asking 200 shipped for it. I do not check these forums regularly.. so please email me at mingchi96@hotmail.com or call me at 214 566 6083. Thanks
Old Jan 16, 2002 | 12:51 PM
vince's Avatar
i have the ACT XTplate and SS full face disc!!! i had around 4 lapping day with that clutch!!! i have no problem during the last lapping day..... i couldn't shift the next day when i was driving down the street!!! finally i need to tow the car back home!!!
the next day i took the tranny out, i thought that's probably the pressure plate problem!!! when the tranny off, the problem is the disc!!!
the disc came with 2 side and some bolts hold them together!!!
one of the side came off!!! so i put my factory back now!!! i am still looking for a new one!!! i will post a pic of the disc later, luckily that my spoon flywheel is ok!!!
BTW, do u think i can go back to ACT???
[Modified by vince, 1:52 PM 1/16/2002]
Old Jan 17, 2002 | 05:50 PM
HybridSI's Avatar
Default Re: ACT CLUTCH QUESTION (vince)
V, look at the center of that disc. Looks like it says EXEDY!!!!! That is because ACT took a STOCK EXEDY unit and REBUILT IT!!!! Just like CM CF and CN Why not get the EXEDY Racing unit and have the REAL DEAL?
Old Jan 17, 2002 | 11:23 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: ACT CLUTCH QUESTION (HybridSI)
I've got the ACT street strip with H/D PP in my R with nitrous. It grabs fine even after 25K miles worth of spraying. The extreme pressure plate is not necessary, especially if it's your daily driver
Old Jan 18, 2002 | 02:21 AM
typer694's Avatar
New User
Default Re: ACT CLUTCH QUESTION (RealTypeR)
Same here, Streat strip disc, and Heavy Duty Preasure Plate. Should be fine, really no need for a 4 or 6 puck disk. This set up grabs like a SOB when your shifting hard, say going down the 1/4 mile strip. The pedal feel isn't much stiffer than stock, perfect for a daily driver. IMO.
Old Jan 18, 2002 | 11:46 AM
BlkITR #1404's Avatar
Default Re: ACT CLUTCH QUESTION (typer694)
I am going to need to get a new clutch soon. How much are the ACT clutch and if i do get a clutch im going to get a flywheel too. Could you guys suggest a price with and without the flywheel. Im a daily driver so i dont need anything too heavy duty. Help me out though cause the stock one feels like its almost gone......
ACTION JACTION
Dec 18, 2009 07:28 PM
urbansi
Mar 7, 2007 12:54 PM
hksturbolude
Oct 14, 2002 07:04 PM
MUGENTYPER
Jan 16, 2002 12:39 PM
baonest
Aug 8, 2001 07:44 PM
