Help! Vacuum leak and i need to know how to find it.
Old Feb 8, 2005 | 12:34 PM
iniquitous's Avatar
Default Help! Vacuum leak and i need to know how to find it.
I would like to find all the vacuum hoses in my 98 prelude and i dont know where to find them. I know this sounds like a dumb question but i am new to this and i want to fix it ASAP. I would also like to know how i can tell if one is leaking. PLease help.
Thanks
Old Feb 8, 2005 | 12:53 PM
Greyout's Avatar
Default Re: Help! Vacuum leak and i need to know how to find it. (iniquitous)
if you're not sure what a vacuum line is, I'd get someone local to help you.
Old Feb 8, 2005 | 04:42 PM
PrettyLude's Avatar
get a can of carb cleaner and start spraying everywhere the second you hear the engine sounding funny, there's your leak
Old Feb 8, 2005 | 04:47 PM
Shakes's Avatar
space cadet
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">get a can of carb cleaner and start spraying everywhere the second you hear the engine sounding funny, there's your leak</TD></TR></TABLE>
hell no! carb cleaner isnt by any means a gental substance. just use a mild cleaner in a spray bottle.
this is close to your vacuum diagram.
Old Feb 8, 2005 | 04:49 PM
Revi's Avatar
I think you will pass out from the fumes before you find the leak....what makes you believe you have a vaccum leak?
Old Feb 9, 2005 | 07:06 AM
ludetunerz's Avatar
If you take it to a shop, they can do a smoke test to trace the leak.
Old Feb 9, 2005 | 07:51 AM
dmxsoulja3's Avatar
Default Re: Help! Vacuum leak and i need to know how to find it. (ludetunerz)
Or get yourself a 20 dollar vacuum tester. Use it in a quiet garage with a buddy, won't be to hard to find.
Old Feb 9, 2005 | 08:05 AM
kulrevon's Avatar
Default Re: Help! Vacuum leak and i need to know how to find it. (dmxsoulja3)
I know this might sound dumb but it works. start pulling of vacuum hoses while the engine is running and where you pull them off cover vacuum port. if the problem stops then you know you have it. Id say start with the less important ones like the ones on the right side of the manifold. then try the back one. then the evap purge , evap canister, and the intake control diaphragm. the only one that should make a difference when you pull it off is the map sensor and you will probably throw a code if you disconnect that one.
Old Feb 9, 2005 | 08:06 AM
98TypeSH's Avatar
the vac diagram is pretty damn simple. retrace all the lines that shakes posted. Look on the intake manifold for any lines not capped and **** like that.
Old Feb 9, 2005 | 10:26 AM
iniquitous's Avatar
Default Re: (Revi-Ra)
Thanks for the reply. To answer your question. My prelude on start up revs up to 1500 to 1800 RPM untill warm. I understand the problem is either a vacuum leak or air in the cooling system. I intend to flush the the radiator and replace the coolint. Maybe you can suggest another way to bleed the air out? I am also going to give all the vacuum lines the once over with some soapy water to see if i can find a leak. If you have any other suggestions please feel free to get back to me.
Old Feb 9, 2005 | 10:40 AM
hOndafienD 04's Avatar
i've always done this with no problem.
Old Feb 10, 2005 | 02:30 PM
jdmaek's Avatar
Default Re: (Shakes)
the last owner put on a intake and he never gave me the intake control diaphragm or the rest of the stock intake(the bottom part that goes down the fender), I been getting this cel p0441 EVAP Emission Control System Improper Purge Flow. the number 8 hoes goes into the fender, but theres no intake control diaphragm to plug in to. I have odb2 h23. everything else looks like it been conected fine and no leaks.
Old Feb 10, 2005 | 05:20 PM
Dante25's Avatar
Default Re: Help! Vacuum leak and i need to know how to find it. (Greyout)
i had a vacuum leak on my car and i just took a little bit of soap water and put it on the ends of the hose and looked for bubbles i found one. but in the end it was my idle position sensor
turbospool980
Jun 24, 2010 01:51 PM
LilCivic04
Sep 9, 2005 11:28 PM
tuan...
Jan 25, 2004 03:45 PM
