Stuck in D4
Old Feb 8, 2005 | 11:47 AM
ViperLX's Avatar
Default Stuck in D4
I have a 92 Honda Accord LX Coupe. Lately I am guessing because of the weather since it got cold, it might be the cause of the problem. Anyways, here is the problem. Whenever I turn on the car the gear is in 4th. I can't change it or anything. I can still go into 2nd and all but when I give it gas the car takes for ever to accelerate. It seems it just stays in 4th and doesn't bother with the 1 2 3. Any way to fix this?
Old Feb 8, 2005 | 08:07 PM
ViperLX's Avatar
Default Re: Stuck in D4 (ViperLX)
bump
Old Feb 9, 2005 | 11:45 AM
ViperLX's Avatar
anyone?
Old Feb 9, 2005 | 11:57 AM
hondadude's Avatar
You need to jumper the service connector and see if you have a code on the trans control unit, it sounds like you have bad solenoids. How long has the light been flashing on the dash?
Old Feb 9, 2005 | 12:05 PM
ViperLX's Avatar
Default Re: Stuck in D4 (hondadude)
i guess a few days now
Old Feb 9, 2005 | 01:24 PM
Luisito825's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViperLX &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 Honda Accord LX Coupe. Lately I am guessing because of the weather since it got cold, it might be the cause of the problem. Anyways, here is the problem. Whenever I turn on the car the gear is in 4th. I can't change it or anything. I can still go into 2nd and all but when I give it gas the car takes for ever to accelerate. It seems it just stays in 4th and doesn't bother with the 1 2 3. Any way to fix this?</TD></TR></TABLE>
when you put the shifter to d4, its actually starting from 1st gear and it moves it way up when you drive. Think of it as d4 means it will use all 4gears. d3 it will use only 3 gears..etc..
if you're pressing the gas and nothing is happening, you're tranny is probably bad, or you're low on fluid, or MAYBE you got a loose wire...
Old Feb 9, 2005 | 06:11 PM
alotawatts's Avatar
Could be a bad solenoid...whens the last time you flushed the trans fuid ?
bigdaddyhonda1
Aug 21, 2013 01:14 PM
collector_164
Apr 30, 2011 07:30 AM
hatzipri90accord
Apr 1, 2011 12:10 AM
brianjung818
Jan 16, 2010 05:59 PM
