Clutch pedal adjustment??
Old Feb 8, 2005 | 11:00 AM
eluder33's Avatar
Default Clutch pedal adjustment??
My clutch seems to engage fully only when my foot is ALL the way to the floor, is there any way I can adjust the engagement point? And if there is do I have to bleed the system again cause I already filled it up and bleed it a few times this month.
Old Feb 8, 2005 | 11:04 AM
Greyout's Avatar
Default Re: Clutch pedal adjustment?? (matty c)
if you filled it up once, and then you were able to add more fluid several times after that, you have a leak in either the master cylinder or the slave cylinder. The offending cylinder should be replaced, and is most likely the cause of the problem.
Old Feb 8, 2005 | 11:12 AM
diewX3's Avatar
Default Re: Clutch pedal adjustment?? (Greyout)
good luck with changing the master cylinder took me a long time, pretty simple though if you think about it
Old Feb 8, 2005 | 04:26 PM
eluder33's Avatar
no its not that, I changed it a few times to flush all the old crap out since it didn't get it all the first time. I doesn't leak at all now.
Old Feb 8, 2005 | 04:35 PM
minimesleeper94's Avatar
sounds like it's about time for a new clutch possibly. when the clutch disc wears too thin then the teeth on the pressure plate start to come out toward the throw out bearing. i am only saying this since you have already added fluid and went through bleading the master cylinder.
Old Feb 8, 2005 | 04:36 PM
BB4's Avatar
BB4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">if you filled it up once, and then you were able to add more fluid several times after that, you have a leak in either the master cylinder or the slave cylinder. The offending cylinder should be replaced, and is most likely the cause of the problem.</TD></TR></TABLE>
straight from the textbook
Old Feb 8, 2005 | 04:37 PM
my bad, i had mis read your post. im at a coffee house and im kinda jacked right now. i thought that it said it would only enguage and disenguage when the peddle was almost all the way out. please ignore anthything that i had just posted.
prodjay10
Honda Civic (2001 - 2005)
Aug 19, 2017 08:08 PM
96civic turbo
Transmission & Drivetrain
Jun 5, 2010 11:09 AM
lsvtec97hatch
Aug 5, 2009 11:21 AM
T"u"Rtle
Apr 21, 2006 10:17 AM
JoJO...
10
Sep 30, 2005 08:56 AM
