Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Only stock alignment parameters in Street Prepared?
Old Feb 8, 2005 | 10:53 AM
Victor Penner's Avatar
Default Only stock alignment parameters in Street Prepared?
It has been awhile since I was involved in Auto-x and so I have been going over the rule-sets for ST,SP, SM etc., and I am surprised that you have to stay within stock camber in SP but not in ST. What is up with that?
Old Feb 8, 2005 | 11:14 AM
maxQ's Avatar
Default Re: Only stock alignment parameters in Street Prepared? (Victor Penner)
Are you reading from a 2005 rulebook? It's been changed. ST camber allowances can now be used in SP. (SP always had allowances for camber on wishbone-shod cars but they weren't as "affordable" as the camber kits in ST... but now it's not an issue.)
Old Feb 8, 2005 | 11:47 AM
carl_aka_carlos's Avatar
Default Re: Only stock alignment parameters in Street Prepared? (maxQ)
yeah, what maxQ said.
btw, SCCA now has the rule books available online, for free!
Old Feb 8, 2005 | 02:49 PM
Default Re: Only stock alignment parameters in Street Prepared? (carl_aka_carlos)
Yes, from the 2005 online version.Where? I will try reading them again.
Old Feb 8, 2005 | 03:57 PM
TeamSlowdotOrg's Avatar
You don't have to stay at factory alignment settings just because wishbone cars aren't allowed to use "camber kits."
Old Feb 8, 2005 | 04:26 PM
Default Re: Only stock alignment parameters in Street Prepared? (TeamSlowdotOrg)
Does anyone have the page # for this please? I can't seem to find it or I am misunderstanding the rule.
Thanks
Old Feb 8, 2005 | 05:04 PM
well Victor, it appears that teh 2005 Solo2 Rules PDF was published before the Fastrak that announces the change.
I'm gonna search the Fastrak archives for you.
Old Feb 8, 2005 | 05:13 PM
Default Re: (carl_aka_carlos)
Wow!! I thought I was going nuts. I probably am nuts, but not right now, maybe.
Thanks, it would be cool if you could point me to the fastrack!
Congrats on the halo removal, I wish you the best of luck
Victor Penner
Old Feb 8, 2005 | 05:21 PM
Searched all the Fastrack's back to Aug '04, couldn't find the allowance. Has all the vicodin gone to my head? Why can't I find the allowance of camber kits in SP???
Old Feb 9, 2005 | 05:14 AM
maxQ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carl_aka_carlos &raquo;</TD></TR><TR><TD CLASS="quote">Searched all the Fastrack's back to Aug '04, couldn't find the allowance. Has all the vicodin gone to my head? Why can't I find the allowance of camber kits in SP???</TD></TR></TABLE>
Did you and I somehow have the same dream!?!?!?
As of December 2004: http://www.sccaforums.com/cgi-...33/5?
As that thread points out, offset bushings will accomplish some of the negative camber you want...
Old Feb 9, 2005 | 07:53 AM
Default Re: (maxQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxQ &raquo;</TD></TR><TR><TD CLASS="quote">
we must have!
Victor, offset delrin bushings are your friend! I think OPM might sell these?
Old Feb 9, 2005 | 09:20 AM
Andy Hollis's Avatar
Gents,
In SP, you have *always* been allowed to run alignment outside of factory specs. Heck, you can even do that legally in Stock!!
The only limitation is in the additional methods used to achieve it (aside from whatever factory adjusters or lack thereof). That's where SP is very specific, and ST allows a bit more creativity in method.
--Andy
Old Feb 9, 2005 | 09:33 AM
Default Re: (Andy Hollis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andy Hollis &raquo;</TD></TR><TR><TD CLASS="quote">In SP, you have *always* been allowed to run alignment outside of factory specs. Heck, you can even do that legally in Stock!!
Andy,
I knew that! Somehow I got the idea stuck in my head (and so did MaxQ) that you are now allowed to swap 1 control arm (upper or lower, not both) in SP to gain camber. But alas, both MaxQ and myself are apparently suffering from the same delusions
Old Feb 9, 2005 | 12:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andy Hollis &raquo;</TD></TR><TR><TD CLASS="quote">Gents,
--Andy</TD></TR></TABLE>
It says that Camber has to be within Factory Spec's , and that any sort of offset bushing are only to bring you back to Spec, not past. Toe is a different matter.
Old Feb 9, 2005 | 12:58 PM
Crack Monkey's Avatar
Default Re: (Victor Penner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Victor Penner &raquo;</TD></TR><TR><TD CLASS="quote">It says that Camber has to be within Factory Spec's , and that any sort of offset bushing are only to bring you back to Spec, not past. Toe is a different matter.</TD></TR></TABLE>
Huh? 13.8 allows alignment outside factory specs (13 is Stock section, 15.1.A says SP inherits all the stock rules).
Old Feb 9, 2005 | 01:00 PM
Anyways, as noted above, you're restricted to adjusting camber through factory means or offset bushings or camber plates (not applicable to double A arm designs). No alternate control arms.
Old Feb 9, 2005 | 01:38 PM
Default Re: Only stock alignment parameters in Street Prepared? (Crack Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">Anyways, as noted above, you're restricted to adjusting camber through factory means or offset bushings or camber plates (not applicable to double A arm designs). No alternate control arms.</TD></TR></TABLE>
Or camber bolts (aka crash bolts). Or lowering by allowed means.
Many ways to skin this cat, just not replacement control arms or ball joints or the like. Not yet, anyway.
--Andy
Old Feb 12, 2005 | 03:24 PM
PupaScoopa's Avatar
Default Re: Only stock alignment parameters in Street Prepared? (Andy Hollis)
I thought ball joints were ok?
Old Feb 13, 2005 | 11:42 AM
Crosser's Avatar
Default Re: Only stock alignment parameters in Street Prepared? (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">I thought ball joints were ok?</TD></TR></TABLE>
In ST classes they are, but not in Street Prepared classes.
jda90
Suspension & Brakes
Aug 19, 2005 10:33 AM
autoxsol
Jul 10, 2003 03:42 PM
mr tl
Sep 7, 2002 09:39 AM
fcuked
Jan 31, 2002 06:29 AM
Caffeine Slug
Sep 28, 2001 09:56 PM
