Intermittent hesitation on 90 Accord EX 5 speed
Old Feb 8, 2005 | 09:10 AM
blueaccord90's Avatar
Default Intermittent hesitation on 90 Accord EX 5 speed
This problem is bugging me to death! When I am accelerating the car will hesitate around 2500-3000 RPM. As I am holding the gas pedal down it will not do anything for a few seconds, then it will kick in. I usually have to push the gas down quite a bit to get it to go again.
This problem only happens every few days or so. It happened to me again yesterday and it seemed worse than before.
I have changed the plugs, plug wires, distibutor cap, rotor button, and fuel filter. I also installed an AEM short ram intake so I know it is not a problem with air delivery to the throttle body.
Does anyone have any suggestions? Any help would be greatly appreciated.
Old Feb 8, 2005 | 09:52 AM
eauto's Avatar
Default Re: Intermittent hesitation on 90 Accord EX 5 speed (blueaccord90)
Check the following threads:
https://honda-tech.com/zerothread?id=1141493
https://honda-tech.com/zerothread?id=1141040
Old Feb 8, 2005 | 09:56 AM
eauto's Avatar
Have you had any of the following problems:
-Check your 02 sensor
-Hows is your guel mileage
-How many miles on the car
etc etc
Old Feb 8, 2005 | 10:17 AM
Default Re: Intermittent hesitation on 90 Accord EX 5 speed (eauto)
How do I go about checking the O2 sensor? The car has 220K on it. I haven't had problems with gas mileage. I ran some fuel injector cleaner through it also.
Thanks for the reply.
Old Feb 8, 2005 | 02:28 PM
I also forgot to mention that my CEL has not come on.
Old Feb 10, 2005 | 06:23 PM
bump.
Old Feb 10, 2005 | 06:24 PM
hondaracin24's Avatar
I like to know more about this as well. Im experiencing the same problem.....
Old Feb 17, 2005 | 02:51 PM
AmonDin's Avatar
Same problem here too, only I have a 93 accord lx with an h22. I let you know if I find out.
Old Feb 17, 2005 | 03:54 PM
AmonDin's Avatar
I forgot to add, I have a 5 spd. as well, and have replaced the MAP sensor, checked the O2 sensor, checked the IAC valve, and am trying a new distributor right now. I'll keep you informed.
Old Feb 24, 2005 | 07:02 PM
Default Re: Intermittent hesitation on 90 Accord EX 5 speed (AmonDin)
Thanks for the reply. I am suspecting maybe the O2 sensor, IACV, EGR valve, ignition module, or distributor. I haven't had the extra money to replace any of these parts yet, but I do have a thermostat that I will be putting in pretty soon.
These type of intermittent problems are so difficult (and expensive) to troubleshoot, especially with no CEL!
Old Feb 24, 2005 | 10:14 PM
accord115's Avatar
same EXACT problem
pretty crappy mileage too about 300 for an i4
Old Feb 24, 2005 | 10:43 PM
AmonDin's Avatar
Thought I'd give you another update... Replaced the distributor and ignition coil, but those were not the problem althought I haven't adjusted the timing on the distributor yet, so that could be the cause. My O2 sensor is good, and when I unplugged my TPS and IAC valve it did not recreate the problem. I'm going to see if I can borrow a timing light from a friend to adjust the ignition timing and see if that fixes it. I'll let you know if I figure anything else out.
Old Feb 25, 2005 | 11:57 AM
SearchBeforeUPost!'s Avatar
I have a leaky rear main seal that leaks oil on the flywheel after a few hours of driving and causes this problem. Check to see if your rear main is leaking.
Old Feb 25, 2005 | 06:36 PM
Default Re: Intermittent hesitation on 90 Accord EX 5 speed (SearchBeforeUPost!)
Thanks for all the replys everyone! I don't think I have any oil leaks, but I will double check for the rear main seal.
Would the TPS or IAC valve cause a CEL if either were malfunctioning?
Old Feb 25, 2005 | 06:47 PM
sincityEX's Avatar
i had the exact same problem... 92 ex w/ auto trans. mine ran great cold but after an hour or so on the freeway it started acting up. no cel just hesitation when i kicked into passing gear or kicked her up above 3500 rpm. replaced the ignitor and it went away. mine would even do it just cruising down the freeway at 70-75. without mashing the accelerator. i threw money at it till i had no ideas left. 45$ ignitor fixed it so, something to think about.
Old Feb 25, 2005 | 08:01 PM
supercreed2002's Avatar
Default Re: Intermittent hesitation on 90 Accord EX 5 speed (sincityEX)
45 bucks for an ignitor??? I paid like 85 bucks for mine!
Caleb
Old Feb 25, 2005 | 09:41 PM
sincityEX's Avatar
Default Re: Intermittent hesitation on 90 Accord EX 5 speed (supercreed2002)
i shopped around big time... auto parts stores break down quick.
Old Feb 26, 2005 | 01:04 PM
knate's Avatar
i have had this problem as well, mine was caused by my old auto tranny and my speed sensor. i can't wait to swap to 5pd :D
Old Feb 26, 2005 | 05:36 PM
Default Re: (knate)
Nice!!! You will be glad you did.
Old Feb 26, 2005 | 07:32 PM
Default Re: (supercreed2002)
I might try replacing the ignitor. That's much cheaper than replacing the complete distributor.
Old Feb 26, 2005 | 09:04 PM
Default Re: (blueaccord90)
True.... I can't even began to imagine how much the distributor will cost, but good luck on fixing the problem!
Caleb
Old Mar 1, 2005 | 09:21 AM
kochtravis's Avatar
Just want to let everyone know that I was having the same exact problem with my GSR. I ended up replacing the O2 sensor and the spark plugs last night and it runs better than ever -- fixed it right up.
Old Mar 1, 2005 | 02:15 PM
Icemanx4's Avatar
Your ignition Distributer and Ignition Coil are about to go out. I had to replace both on my 93 accord. The rpm needle would just drop and all of a sudden jump back after a few seconds. Sounds like the same problem I've got 180,000 on mine. If you've never replaced it was $680 w/labor.
voodooutt
May 31, 2013 08:43 AM
deyomatic
Feb 13, 2008 07:55 AM
blueaccord90
Jun 27, 2005 01:37 PM
dtamminx
Apr 16, 2005 08:14 PM
