not shifting
i have a 93 accord and it isn t shifting but if i take the cables off the gear box on top the transmission the work and its a low mile transmission i just got cause my other one was stuck in 3rd gear . could it be the gear box on top of the transmission that is bad . or does anyone have any ideas
First off grammer is your friend, helps people follow your train of thought.
Second what gear box on top of the transmission? Do you mean the shift/select mechanism and forks?
The accord shifts by cables as you mentioned, there is no adjustment really to go out of whack. What I mean is the H style shifting pattern is the select/shift on the transmission itself (disconnect the cables and you can move the stick any which way), in my experience there is no fine tune adjustment that would keep it from shifting. If it won't shift its either the transmission, or the clutch isn't disengaging (bad master/slave cylinder, bent fork, or air in the lines).
Good luck, hope that helps.
P.S. There's really no need to get new transmissions. I fixed mine so I could go in reverse again simply by grinding my knurled 5th gear smooth with a dremel tool. Worst case scenario you buy a new gear not a new tranmission.
Modified by Schmitey at 10:21 PM 2/8/2005
Yangpho
Aug 20, 2015 10:48 PM
