Trying to remove flywheel
I'm trying to remove my flywheel with no air tools, I don't have to money to buy a compressor and air gun and new sockets. I was wondering if there is a way to remove the stock flywheel with just sockets and leverage. Also I'm tying to get the flywheel no to spin by placing a brick in between the teeth and the ground, but the flywheel just turns. Any thing I could to keep the flywheel from moving. TIA
get someone to hold the main crank bolt with a 17mm piece + a ratchet or breaker bar from the opposite side- then taking those 12mm flywheel star bolts out shouldnt be a problem at all.
the only way i got mine off (motor removed from the car) was with an electric impact and i just laid into it... it wasnt the easiest thing i've ever done... i'm not sure how i'd get it off without it... but i also tried without an impact of any kind and it basically just didnt work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennjamin@ozhonda.com »</TD></TR><TR><TD CLASS="quote">get someone to hold the main crank bolt with a 17mm piece + a ratchet or breaker bar from the opposite side- then taking those 12mm flywheel star bolts out shouldnt be a problem at all. </TD></TR></TABLE>
Thanks I'll try this out. I hope it works.
pantherninja
Dec 11, 2011 06:14 PM
JDMInspired
Honda Civic (2001 - 2005)
Mar 17, 2008 08:57 AM
