help w/ ls motor swap
Old Feb 7, 2005 | 08:43 PM
NW94RS
Guest
Posts: n/a
Default help w/ ls motor swap
ok my friend and i were helping our friend put in a obd1 ls motor into his obd1 92 si everything went smoothly and we got the car running and we left the car running for about 5 minutes.
so here's where i need help
my friend pulls one of the plug wires and the car sputters and dies. we try and restart it and it wont start.
-so we check for spark by taking out the plug and touching it to the valve cover and nothing happens. no spark
-then we take the plug from the distributor and there's still no spark.
so now we don't know what to do. and were about to buy a new distributor tomorrow but we don't want to pay for something if we don't have to.
what do you guys think might be wrong.
thanks for any help.
SEAN
Old Feb 7, 2005 | 10:14 PM
PrettyLude's Avatar
the ignitor died?
Old Feb 7, 2005 | 10:19 PM
NW94RS
Guest
Posts: n/a
Default Re: (PrettyLude)
im just looking for a smorgish board of ideas for tomorow when we combat this.
Old Feb 8, 2005 | 12:07 AM
Redline130's Avatar
Default Re: (NW94RS)
I guess first thing you could do is to try a good, working distributor and trouble shoot from there. CEL's?
Old Feb 8, 2005 | 09:34 AM
Katman's Avatar
Default Re: help w/ ls motor swap (NW94RS)
how long was the car running when you guys pulled out the spark plug wire while the engine was running?
maybe check teh spark plug and see if its fouled or f'd up...
Old Feb 8, 2005 | 09:39 AM
NW94RS
Guest
Posts: n/a
Default Re: help w/ ls motor swap (K@man)
the car was running for about 5 minutes we pulled all the plugs and there all fine, im starting to think that we broke the timing belt, but lets all say a prayer that, that didnt happen.
Old Feb 8, 2005 | 10:09 AM
Katman's Avatar
why would the timing belt break if you removed the spark wires ? lol..
when you try and turn the car on, does the engine crank/spin, but just not start up?
Old Feb 8, 2005 | 10:57 AM
NW94RS
Guest
Posts: n/a
yep
Old Feb 8, 2005 | 02:00 PM
JdmLsPwr425's Avatar
its my car...i need help please
Old Feb 8, 2005 | 03:40 PM
primeredbeast's Avatar
Default Re: help w/ ls motor swap (JdmLsPwr425)
sounds like your firing order is either wrong or something in the distributor took a crap on ya
Old Feb 8, 2005 | 04:57 PM
Default Re: help w/ ls motor swap (primeredbeast)
i think its the distributor...we'll see
Old Feb 8, 2005 | 08:23 PM
sickerhatch's Avatar
chech the firing order!!!
Old Feb 9, 2005 | 08:05 AM
Default Re: help w/ ls motor swap (sickerhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickerhatch &raquo;</TD></TR><TR><TD CLASS="quote"> chech the firing order!!!</TD></TR></TABLE>
done that
Old Feb 9, 2005 | 08:43 AM
TURBO4drTypeR's Avatar
If you have no spark then its your ignition coil
Old Feb 9, 2005 | 10:37 AM
blackeg's Avatar
Default Re: help w/ ls motor swap (TURBO4drTypeR)
if your problem lies within the distributor(as it sounds it does) i highly recommend seeing if you can borrow a working distributor from someone for a quick second to see if yours went bad. coils and ignitors are like over a hundred bucks each, which is way to expensive to be replacing just upon a hunch. trust me, i was in the exact same situation one year ago
Old Feb 10, 2005 | 06:47 AM
Jmunk's Avatar
Sounds like you killed the ignitor by pulling a wire off when it was running, I've heard of this happening before.
Old Feb 12, 2005 | 11:52 AM
Default Re: help w/ ls motor swap (blackeg)
ya i found the problem, replaced the distributor and it works now..thanks everyone
Old Feb 12, 2005 | 03:28 PM
Katman's Avatar
tiiite boy.
jdm. hot stuff.
Old Feb 19, 2005 | 11:09 AM
mikeslshatch's Avatar
Default Re: (Katman)
soundslike the dis man look for a used one first
FTNW
Dec 7, 2010 01:10 PM
92durtyintegraGS
Nov 7, 2009 09:23 AM
Supahatch
Oct 31, 2009 09:08 AM
Armorzaku
Feb 21, 2009 02:29 PM
GTA
16
Jun 15, 2004 10:21 PM
