steel braided lines
Old Feb 7, 2005 | 08:14 PM
drunknbass's Avatar
Default steel braided lines
i was going to hide all mybrake ines cause i wanted to clean my engine bay up. so i was going to do steel braided lines from the MC to the prop and from the prop to the front brakes. and i was going to cut the hardlines that run to the rear right under the firewall and reflare the fitting onto them.
so my ? is what size are steel braided brake lines, and what are the regular fittings that go into the prop and mc called? and what fittings can i put on the steel braided that run to the rear that will atach to the hardline fitting (female fitting, like the threads of a mc)
Old Feb 7, 2005 | 08:17 PM
Quad-Damag's Avatar
Default Re: steel braided lines (drunknbass)
this is for a eg btw
Old Feb 7, 2005 | 08:39 PM
drunknbass's Avatar
heres my cheesy drawing.. the blue are the steel braided lines..
the drawing of the fittngs are the appropriate fittings i need to attach to the steel braided lines.
Old Feb 7, 2005 | 08:56 PM
Quad-Damag's Avatar
nice pic
Old Feb 7, 2005 | 08:57 PM
drunknbass's Avatar
Default Re: steel braided lines (Quad-Damge)
thanks
Old Feb 7, 2005 | 09:29 PM
RangerDan's Avatar
hmm..cool idea.
Sorry Im no help.
Old Feb 7, 2005 | 09:35 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: steel braided lines (RangerDan)
why would u do that? The metal lines are ideal b/c they wont expand when u increase the pressure by stepping on the brakes. I guess changing it to steel braided lines wouldnt make a diference, but why spend the money and time to change something thats already ideal? If u gonna change the lines, change the rubberones from the calipers to the hard lines. U can even change the rubber clutch line to steel braid if u wanted.
Old Feb 7, 2005 | 10:14 PM
HeikDiesel's Avatar
Default Re: steel braided lines (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">why would u do that? The metal lines are ideal b/c they wont expand when u increase the pressure by stepping on the brakes. I guess changing it to steel braided lines wouldnt make a diference, but why spend the money and time to change something thats already ideal? If u gonna change the lines, change the rubberones from the calipers to the hard lines. U can even change the rubber clutch line to steel braid if u wanted. </TD></TR></TABLE>
I dont think you understand what he is saying. Hes wanting to hide all of his lines so if he uses semi flexable lines such as steel braided, he will be able to tuck them away under stuff where as the hard lines are where they are peroid. As for the idea...I wanna see it done.....I think your goin overboard cuz thats a lot of money just for a "clean" look
Old Feb 7, 2005 | 10:27 PM
Gump's Avatar
Default Re: steel braided lines (PhatAcuraIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">
As for the idea...I wanna see it done.....I think your goin overboard cuz thats a lot of money just for a "clean" look </TD></TR></TABLE>It's already been done...
https://honda-tech.com/zerothread?id=957195
Old Feb 7, 2005 | 10:29 PM
MrEG6er21
Guest
Posts: n/a
Default Re: steel braided lines (Gump)
[/QUOTE]
One Sexy engine I will say.
Old Feb 7, 2005 | 10:33 PM
Ls1 FD3s's Avatar
Default Re: steel braided lines (MrEG6er21)
Na is best if you love the same gender... I hate that stupid sticker, totally ignant..
That engine bay is damn clean.
Old Feb 7, 2005 | 10:35 PM
HeikDiesel's Avatar
Man I completly forgot about that car, its even the background on my computer! Hey gump are those 3 lines in the wirewall just where he decided to run the lines rather than under the car?
Old Feb 7, 2005 | 10:41 PM
Gump's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Man I completly forgot about that car, its even the background on my computer! Hey gump are those 3 lines in the wirewall just where he decided to run the lines rather than under the car?</TD></TR></TABLE>Don't know, my guess would be he ran it there so that all the lines were of equal length to the proportioning valve.
Old Feb 7, 2005 | 10:46 PM
drunknbass's Avatar
yup thats the car that i got the idea from.. my car is getting painted roght now so i was just gonna do this when i reassemble it. and then hide the engine bay wires and thats about ti. makes it alot cleaner. just dont know the correct diamiter steel braided line to use.
Old Feb 7, 2005 | 11:18 PM
dkim48's Avatar
Default Re: (drunknbass)
just take your hard lines to some place like earl's performance or any other shop that specializing in plumbing. they usually have all the sizes you need for something like this
Old Feb 7, 2005 | 11:46 PM
drunknbass's Avatar
Default Re: (dkim48)
yea i was gonna try and get it all off ebay cause its cheaper. i read somewhere that the best size to use is -3 an but im wondering if -4 would work cause its alot easier tofind.
rhdekhatchie
Suspension & Brakes
Dec 11, 2008 07:31 AM
94CivicSi
18
Mar 28, 2008 05:03 AM
guymosiris
Jun 29, 2006 12:55 PM
Pandahatch
Suspension & Brakes
May 22, 2005 11:28 AM
