D series TB on 1st gen B16?
I believe they are interchangeable as long as they abide by obd's .... becuase the obd-1 throttlebody has the map sensor integrated into it . I know the B16a OBD-I throttle body will bolt upto a d16z6 manifold (OBD-I)
I am not sure if this helps, but when I swapped my im to a skunk2, I had to use a d16 tb gasket to fit right. To me that would suggest that the im's would be different, but I can't say for sure. I only say this because I had some vacuum isssues after the swap until I changed the gasket to a d16 one. This probably doesn;t help, but maybe someone else can elaborate.
-Shane
-Shane
well im gonna get a skunk2 manifold but i need to convert the 1st gen b16 to obd-1. my block doesnt have an intake manifold on it. But im trying to save some money cause tb are expensive. so i was thinking i can use the stock d series one?
UnrealSpeed
Sep 22, 2003 09:43 PM
ATS_Antone
Nov 8, 2002 07:18 PM
