A/F Ratios
Old Jan 16, 2002 | 08:03 AM
coquinn's Avatar
Default A/F Ratios
When you guys are dyno tuning, what kind of A/F ratios are you shooting for? I'm used to tuning DSM's, so we usually shoot for around 12.5:1 - or around 0.90V on the Jumptronix. So, on a naturally-aspirated Honda/Acura, do you shoot for around 14.0:1 - around 0.75V or even leaner?
Also, are you guys dynoing in third or fourth gear?
Thanks a lot!
Old Jan 16, 2002 | 08:32 AM
sgT's Avatar
sgT
Default Re: A/F Ratios (coquinn)
On turbo cars I use the air fuel ratio to keep things safe and rich.
With NA cars it doesnt really matter too much as long as its not dead lean.
I jsut do what makes more power. if a motor likes it a little rich/lean then
so be it.
Old Jan 16, 2002 | 08:35 AM
HX_Guy's Avatar
Default Re: A/F Ratios (sgT)
Yea, I agree with sgT...I just shoot for whatever the motor likes. Mine seems to like 12.0-12.5:1 and its all motor.
Old Jan 16, 2002 | 09:12 AM
MadtownSi's Avatar
So on a NA B16 is 13.5-14.0 to lean?? I have been told 12.5-13.0 is what a person should shoot for but I'm around 14.0-14.7 most of the time. Yoshio at in Toronto tuned my car but I'm wondering if he leaned things out too much.
Old Jan 16, 2002 | 09:13 AM
sgT's Avatar
sgT
Default Re: A/F Ratios (MadtownSi)
only way to tell is to add fuel and see if you make more power.
Old Jan 16, 2002 | 09:25 AM
HX_Guy's Avatar
Here is my friend's B20VTEC after we tuned the A/F Ratio. We could not make it any richer at 6000 for some reason. He is using a Skunk2 chip
Blue = 40 PSI fuel / 0 settings on VAFC
RED = 50 PSI VAFC change - 55k-65k=+10% 65k-8k= +5
Old Jan 16, 2002 | 09:28 AM
Black R's Avatar
25 Year Member
.....also check your plugs.
092eg6
17
Dec 12, 2009 04:21 PM
b18c_ek
Nov 4, 2004 05:59 PM
Cyber ITR
Sep 18, 2003 10:04 AM
95TurboLS
Sep 2, 2003 05:58 PM
oryanh
Nov 26, 2001 12:22 PM
