I NEED SOME HELP IN ADJUSTING E BRAKE
Old Feb 7, 2005 | 05:43 PM
SOCH V-TEC's Avatar
Default I NEED SOME HELP IN ADJUSTING E BRAKE
I TIGHTENED THE LIL NUT ON THE DRUM BRAKE OF MY 2000 EX SO I COULD PUT THE DRUM BACK IN AND NOW MY EBRAKE IS LOOSE LIKE ITS NOT ENGAGING OR SOMETIN HOW DO I ADJUST IT??
Old Feb 7, 2005 | 05:45 PM
jlacoy82's Avatar
71.192.16.183
Default Re: I NEED SOME HELP IN ADJUSTING E BRAKE (SOCH V-TEC)
Either adjust the nut you tightened in the drum, or adjust the cables where they come up through the floor into the center console.
Old Feb 7, 2005 | 06:05 PM
AutoXer's Avatar
You may have loosened it too much. Have you tried breaking by going back / forward a few times so the auto tensioner can work?
Also, please turn off the caps lock.
Old Feb 7, 2005 | 06:33 PM
ABK's Avatar
ABK
Default Re: I NEED SOME HELP IN ADJUSTING E BRAKE (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">You may have loosened it too much. Have you tried breaking by going back / forward a few times so the auto tensioner can work?
You don't want to really go thru auto tensioner. Take off the drumps mark their posstion (on studs) and use a little adjuster to make them tighter.
Old Feb 8, 2005 | 05:01 AM
SOCH V-TEC's Avatar
IL SEE DA CABLES CUZ THERE IS NO WAY TO ADJUST THE LIL SCREW NUT THING WITHOUT TAKING OF THE DRUM CUZ I TIGHTENED IT SO THE DRUM COULD FIT BACK IN BUT I TIGHTNED IT A LIL TOO MUCH I GUESS ILL CHECK DA CABLES THNXS
Old Feb 8, 2005 | 02:41 PM
ABK's Avatar
ABK
you can loosen up DA thing too DUDE. You might also want to machine your drums, and don't mess with cables you will create big drag on your drums.
Accord1234
Sep 1, 2008 06:35 PM
LU
Aug 14, 2008 07:56 AM
duyfash0
12
Sep 5, 2007 04:02 PM
BG-Teg
Feb 26, 2007 11:15 AM
EJ1_519
Dec 17, 2003 07:38 PM
