What size of injectors do i need.....
i got a 96' B18C with intake manifold, header, intake, full MSD ignition, fuel rail, fuel pressure regulator, cam gears, stage 4 clutch, flywheel, V-tec controller, and a few other things, what size of injectors do all you recommend i should get for my set up now? and what size do you recommend i get when i supercharge it? thanks for your time!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybridwill »</TD></TR><TR><TD CLASS="quote">i got a 96' B18C with intake manifold, header, intake, full MSD ignition, fuel rail, fuel pressure regulator, cam gears, stage 4 clutch, flywheel, V-tec controller, and a few other things, what size of injectors do all you recommend i should get for my set up now? and what size do you recommend i get when i supercharge it? thanks for your time!</TD></TR></TABLE>
Stock will be fine with your current set-up. When you supercharge, you should be using a FMU, so you won't need larger injectors.
From what I've seen on here, and since you've got to the trouble of upgrading the rest of your fuel system, 310's are a good choice for an NA setup like yours. leaves some room for more fuel w/o working the stock ones too hard.
