Post-seafoam oil pics
Old Feb 7, 2005 | 01:27 PM
.BigSexy's Avatar
most hood white kid
Default Post-seafoam oil pics
So I seafoamed yesterday, and changed my oil today, here's what it looked like
oil:
pretty nasty
and I also changed my plugs and here are pics of those
plugs:
or
you decide
Old Feb 7, 2005 | 01:29 PM
jlacoy82's Avatar
71.192.16.183
Go look in your oil catch pan to see what kind of nasty **** in still in the bottom of it.
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Post-seafoam oil pics (egcoupe94)
I dont think your supposed to have oil all over your plugs
Old Feb 7, 2005 | 01:32 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Post-seafoam oil pics (walker111)
He might have really dirty sockets?
Old Feb 7, 2005 | 01:34 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">I dont think your supposed to have oil all over your plugs </TD></TR></TABLE>
I was thinking the same thing?? or I think I might have gotten them oily from toughy them with my oily hands
BrianDelSol's Avatar
Default Re: Post-seafoam oil pics (jlacoy82)
If I remember correctly your plugs should be allmost spotless...
Old Feb 7, 2005 | 01:37 PM
.BigSexy's Avatar
most hood white kid
i dont know, i will take my recent plugs out in a week and see what they look like
Old Feb 7, 2005 | 01:38 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (egcoupe94)
Well, yes, they should be spotless clean assuming your spark plug tube seals arent leaking. Also the tips should be anywhere from black/white/brown. Looks like you're running lean on one cylinder (the white one) correct?
Old Feb 7, 2005 | 01:44 PM
.BigSexy's Avatar
most hood white kid
it could have been the cylinder that was leaking coolant when i did my headgasket change, i am not sure, I just threw those dirty things in the trash. how do I replace the spark plug tube seals if they are in fact leaking??
Old Feb 7, 2005 | 01:50 PM
SOHCD16y8's Avatar
I hope you got rid of the AC's when swapped plugs AC+Honda=waste of money
Old Feb 7, 2005 | 01:53 PM
92WhiteHatch's Avatar
Default Re: (SOHCD16y8)
To change the tube seals you have to pull the valve cover.
Old Feb 7, 2005 | 09:05 PM
.BigSexy's Avatar
most hood white kid
Default Re: (92WhiteHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92WhiteHatch &raquo;</TD></TR><TR><TD CLASS="quote">To change the tube seals you have to pull the valve cover.</TD></TR></TABLE>
i figured that, it has to be more complex than that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">I hope you got rid of the AC's when swapped plugs AC+Honda=waste of money</TD></TR></TABLE>
Yeah I did, Bosch sucks ***** as well...NGK ownz!!
Old Feb 7, 2005 | 09:09 PM
Street Ghost's Avatar
the plugs look nasty, but the oil looks like any other oil change to me.
Old Feb 7, 2005 | 09:11 PM
inane's Avatar
speaking of plugs... white means its running lean, correct? lean is when there is lack of oil?
my spark plugs are usually white...
but my car eats oil...
i go through about a quart of oil every week
there are no leaks so i know its not leaking out
when i start the car after its been sitting awhile, theres white exhaust... once the car is warmed up it goes away...
so if its running lean and not getting oil... yet i lose a quart a week... then where could my oil go?
Old Feb 7, 2005 | 09:18 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Post-seafoam oil pics (inane)
Lean is when your air fuel ratio has too much air. More fuel = rich, too much air = lean.
Old Feb 7, 2005 | 09:20 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inane &raquo;</TD></TR><TR><TD CLASS="quote">speaking of plugs... white means its running lean, correct? lean is when there is lack of oil?
so if its running lean and not getting oil... yet i lose a quart a week... then where could my oil go?</TD></TR></TABLE>
hell i dont know<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Edge.ONE &raquo;</TD></TR><TR><TD CLASS="quote">the plugs look nasty, but the oil looks like any other oil change to me.</TD></TR></TABLE>
yeah, it seemed to be a bit on the blacker side this time, my buudy just told me it might be the valve seals as to why the plugs are oily...any comments?
Old Feb 7, 2005 | 09:23 PM
inane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Lean is when your air fuel ratio has too much air. More fuel = rich, too much air = lean.</TD></TR></TABLE>
ahh... so it could be the fact that i have a cold air intake and thats it? its grabbing more air from the intake and less fuel? or my fuel pump needs replaced?
Old Feb 7, 2005 | 09:41 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
looked just like my oil when i did the seafoam. I hope u are putting in some denso's or NGK plugs. Those AC look pretty bad
Old Feb 7, 2005 | 09:49 PM
ahh... so it could be the fact that i have a cold air intake and thats it? its grabbing more air from the intake and less fuel? or my fuel pump needs replaced?</TD></TR></TABLE>
your ECU should be able to compensate for the extra intake in air and add fuel accordingly. its not like your boosting or anything. maybe you need a tune-up.
and those plug look pretty nasty. check your compression.
Old Feb 7, 2005 | 10:03 PM
CivicHatchback14's Avatar
Default Re: Post-seafoam oil pics (_Edge.ONE)
doesn't look good man. Your plugs definatly should not look like that.
Old Feb 7, 2005 | 10:04 PM
t0ekn3e's Avatar
those plug look nasty when i seafoamed my motor and i did my oil change it wasnt too bad like any other oil change but yours looks black man, or it might be becuase of the pics
Old Feb 7, 2005 | 11:02 PM
.BigSexy's Avatar
most hood white kid
Yeah, I went with NGK this time, I don't know hwy I got AC Delco last time, I think Auto Zone was out of NGK.....anyone know what the cause of the super ugly pugs could be?
Old Feb 8, 2005 | 12:05 PM
SOHCD16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah I did, Bosch sucks ***** as well...NGK ownz!! </TD></TR></TABLE>
Yeah i had +4's for a while and they ran like crap, they always made my wires pop off too, switched to denso iridiums and i love them
Old Feb 8, 2005 | 12:10 PM
CivicSiR's Avatar
If your plugs are white that means your A/F ratio is off and your getting too much air. If your car eats oil it may be a sign that you have failing valve seals...or bent valves, or your piston rings are going. Best bet is to do a leakdown test. White exhaust is better than other color exhaust. Lean means not enough fuel. If you wanna try a quick fix...reset your ECU.
Old Feb 8, 2005 | 12:26 PM
.BigSexy's Avatar
most hood white kid
Default Re: Post-seafoam oil pics (CivicSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiR &raquo;</TD></TR><TR><TD CLASS="quote">
If your plugs are white that means your A/F ratio is off and your getting too much air. If your car eats oil it may be a sign that you have failing valve seals...or bent valves, or your piston rings are going. Best bet is to do a leakdown test. White exhaust is better than other color exhaust. Lean means not enough fuel. If you wanna try a quick fix...reset your ECU.</TD></TR></TABLE>
and how would u go about doing this?
