help: 96 civic with swap ls problem
Old Feb 7, 2005 | 01:26 PM
94_civicEx's Avatar
Default help: 96 civic with swap ls problem
can anyone help my car starts up for about 30 seconds then it dies and for that 30 seconds the engine sounds bad and run rich and there is a knock from around the tranny
Old Feb 8, 2005 | 01:40 PM
IROSOLO's Avatar
Default Re: help: 96 civic with swap ls problem (94_civicEx)
MAKE SURE THE TIMING GEAR IS SET RIGHT. I HAD THE SAME PROBLEM WHEN I INSTALLED THE LS IN MY EK.. THE CAM GEAR WAS OFF A TOOTH SO IT RAN LIKE **** AND DIED TOO.
Old Feb 8, 2005 | 01:54 PM
94_civicEx's Avatar
Default Re: help: 96 civic with swap ls problem (IROSOLO)
i found out what the problem is now the runs but then when you rev the engine to like 2000 and up the car feels like it's going to die and some time it die i change the iacv to a two wire if that helps
Old Feb 8, 2005 | 01:59 PM
LShatchie's Avatar
i cant almost bet ur cam timing is off.. i did a ls swap in my 93 hatchback and mine would act like urs and after messing around with it so much and coming up with nothing i said screw it and took it to a shop near my house. They put my car on a dyagnostic machine and found out that my cam timing was off, so all together for the test and to fix it, it was only like $65. There was a few other problems like one of my injectors was bad and i had a iacv problem too, but the main thing was the cam timing...its all good now tho
Old Feb 8, 2005 | 02:03 PM
94_civicEx's Avatar
Default Re: help: 96 civic with swap ls problem (civichatch6989)
i will try that
thanks
Old Feb 8, 2005 | 02:30 PM
94_civicEx's Avatar
could it be that i don't have the crank sensor that would cause it to do that??
Old Feb 8, 2005 | 02:34 PM
hybrid_vtec's Avatar
What about ignition timing or your spark plug wires? Make sur the spark plug wires are on right.
Old Feb 8, 2005 | 02:38 PM
94_civicEx's Avatar
Default Re: help: 96 civic with swap ls problem (hybrid_vtec)
it was my spark plug wires put on wrong and now it run but like i said if u step on it or rev it up feels like dying and sometimes it dies
Old Feb 8, 2005 | 03:08 PM
IROSOLO's Avatar
It sounds like your flooding the motor when you step on the gas. That upgraded fuel system do you have.
Old Feb 8, 2005 | 04:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IROSOLO &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like your flooding the motor when you step on the gas. That upgraded fuel system do you have.</TD></TR></TABLE>
Old Feb 9, 2005 | 12:24 PM
94_civicEx's Avatar
the fuel system has not been upgrade stock
Old Feb 10, 2005 | 01:57 PM
IROSOLO's Avatar
When you step on it does it make a loud knocking sound from the motor?
Old Feb 13, 2005 | 06:02 PM
94_civicEx's Avatar
no there is no sound it just drops all the way down to like 50 to 100 rpm and stays there for a seconds then rise back up but if u step on it hard then it dies
Old Feb 15, 2005 | 10:00 AM
IROSOLO's Avatar
Yeah sounds like you have a fuel issue. Its flooding the motor. I had the same problem. Make sure your fuel regulater is good. It seems that its not sending the fuel back to the fuel tank fast enough and making the motor flood out. What does the fuel pressure read?
Old Feb 15, 2005 | 11:44 AM
94_civicEx's Avatar
reads about 47 psi
Old Feb 16, 2005 | 09:12 AM
IROSOLO's Avatar
WOW. I think thats the problem right there. The pressure is too high. Adjust it down to 33-35psi. If you have a stock fuel regulator then you can't adjust anything. But if you have an after market one then adjust it down to that. I had the same problem with my swap. I put an aftermarket fuel pump on and it read 80psi ll the time and everytie I step on the gas the car wouldn't move and dies. Buy the big AEM one because the little baby stock replacemnt one can't release the extra fuel back fast enough and you really can't adjust it low enough. But since you stated the fuel system is stock then your be ok with the stock replacement.
Old Feb 16, 2005 | 11:33 AM
94_civicEx's Avatar
thanks
Old Feb 16, 2005 | 12:00 PM
IROSOLO's Avatar
No problem. Let me know if fixes the problem.
Old Feb 17, 2005 | 10:45 AM
94_civicEx's Avatar
have not change it yet because i took the timeing belt off to check timing but i will let u know and would u happen to know why the heat and air don't work no more it was work when i started up the car then later it died ?
Old Feb 17, 2005 | 10:52 AM
IROSOLO's Avatar
Try checking the fuse on it. I bet its that. If the fuse is good then more likely the heater motor went out.
Old Feb 17, 2005 | 11:20 AM
94_civicEx's Avatar
it was working when we started the car then it just die the fuse is still good
Old Feb 17, 2005 | 12:27 PM
IROSOLO's Avatar
Wow, ummmm.. It could be a number for things now. Like the heater/blower relay, Blower motor could of went bad, To tell you the truth I wouldn't know where to start on that issue. Sorry.
Old Feb 17, 2005 | 12:36 PM
94_civicEx's Avatar
ya that is cool
but where is the heater/blower relay
Old Feb 17, 2005 | 12:39 PM
IROSOLO's Avatar
What kind of car do you have?
Old Feb 17, 2005 | 12:47 PM
IROSOLO's Avatar
Sorry retarded question. It should be located by the battery in the engine compartment on the passenger side. It should be in a black box with other fuses and relays. the cap on the box should state what relay is the blower.
