90 DX Hatch WON'T start ???
Old Feb 7, 2005 | 01:21 PM
htwanky2a's Avatar
Default 90 DX Hatch WON'T start ???
Ok I have this 90 DX hatch that is really being a pain. The thing died on my friend and hasn't started since. The car was running and just stopped one day. He gave the car to me. I am trying to fix the car and use it as my daily driver. Since I have had the car I replaced the main fuse and the distributer and the coil and I am no closer to getting it to start. The fuel pump does turn on and the car cranks but I have no spark? All the grounds look fine and the car was running fine up to the day that it just stopped while on the road. I don't have any more ideas. If anyone has any suggestions I would appreciate it.
Old Feb 10, 2005 | 10:00 AM
htwanky2a's Avatar
Default Re: 90 DX Hatch WON'T start ??? (htwanky2a)
I'm even open to educated guesses at this point so if anyone has anything please reply.
Old Feb 10, 2005 | 10:05 AM
EP3_05's Avatar
Is the ecu giving any error codes? To me it sounds like a timing issue. Check ignition and cam timing and make sure both are set to spec. How did you check that you didn't have any spark?
Old Feb 12, 2005 | 09:32 AM
htwanky2a's Avatar
Default Re: 90 DX Hatch WON'T start ??? (91civic)
You're right I didn't check ignition and cam timing the car was running and just quit one day. I assumed that the timing was on but maybe i'm wrong? Either way there is no spark and I got no ride. It sux
Old Feb 12, 2005 | 10:10 AM
thumbtack's Avatar
check the wiring on the dizzy for breaks/grounding out. Try a known good dizzy from a friend or something to rule out that your dizzy might be bad. I bought a new one from distributor king, and it was junk... had to pay 500$ for a new OEM one, but my codes went away.
Old Feb 12, 2005 | 10:14 AM
ssl2k's Avatar
Replace the coil inside of the dist.
95% sure that is the problem.
They like to burn themselves out.
Old Feb 12, 2005 | 01:18 PM
htwanky2a's Avatar
Default Re: (ssl2k)
have tried 3 dist. 2 of whic I know are good and each had a different coil so I have ruled out dist and coil I think
Old Feb 12, 2005 | 01:25 PM
ssl2k's Avatar
spark =
ecu, wiring, spark plugs, spark plug wires, dist
has to be one of them
Old Feb 13, 2005 | 10:16 AM
MAXFLOW2's Avatar
Default Re: (ssl2k)
I had a 90 teg ls that died on the road. No spark either. 10 hours later it was found out to be a worn ignition switch. Take of the plastic arond the column and try to work the wires going to it. It may just fire up. If it does shut it off and go get a new switch. Don't try driving as it will just die again. Always remember to look at the ENTIRE wiring diagram. Check and test everything before buying parts and guessing. This is costly as most electronics are non-returnable.
Good luck!
Old Feb 13, 2005 | 02:09 PM
crxtreme89h's Avatar
Default Re: (MAXFLOW2)
He said he had no spark though so I would rule out ignition in that case. However, he never stated how he knows he has no spark. How did you check spark?
Old Feb 13, 2005 | 02:44 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (crxtreme89h)
Make sure the camshaft is rotating..
If the timing belt breaks,the distributor won't turn which
will keep it from firing also..
Pull the distributor cap off and have someone turn it over
while you watch for the rotor to spin..
Old Feb 13, 2005 | 03:38 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (88DXCRX)
Bad ignitor?
Old Feb 13, 2005 | 03:40 PM
ssl2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">Make sure the camshaft is rotating..
Or like my d15b2 I snapped the cam
Old Feb 13, 2005 | 03:48 PM
88DXCRX's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Bad ignitor?</TD></TR></TABLE>
That would be my next quess also,
Especially if the ignitor says "OKI" on it..
That one was recalled and I have had two of them fail on me..
He did say he replaced the distributor...
But you never know if the replacement is OK or not..
Modified by 88DXCRX at 1:45 PM 2/15/2005
Old Feb 14, 2005 | 08:28 PM
htwanky2a's Avatar
I checked for spark by pulling a plug and grounding it. Haven't tried the ecu yet that may be it?
Old Feb 14, 2005 | 08:39 PM
kulangot's Avatar
did you try this?
Old Feb 15, 2005 | 10:05 AM
htwanky2a's Avatar
Default Re: (sirq2u)
Yes I did make sure the cam is rotating so check that one off the list. I stillneed to swap ecus. Tryin to find one layin around someplace at the moment. that is my next attempt.
Old Feb 15, 2005 | 06:46 PM
88DXCRX's Avatar
Default Re: (htwanky2a)
Pull the spark plugs out and make sure they are clean and dry..
trouble-shooting tips: http://autorepair.about.com/cs...a.htm
Magick211
46
Dec 20, 2008 08:53 PM
chuck403
12
Jul 16, 2008 04:40 PM
gordonsnow1978
10
Jan 6, 2007 08:36 PM
SteveeeO
Jul 31, 2003 06:33 AM
DragII
Apr 9, 2003 04:40 PM
