91mm bore H22
I am about to purchase my friends H22 block with Eagle rods, Weisco pistons, iron sleeves, and such. I am just wondering about the reliability of a 91mm bore for street use. I will be running around 11.5:1 comp. on pump gas. He ran it in his hatch before with a milled head, and got some awesome times out of it. I am just trying to run it on the street though. Any help would be awesome. thanks.
Modified by darkdementshun at 12:52 PM 2/7/2005
Is it already 91 or you're thinking of going 91? I wouldn't go any bigger than 89 for a street motor with that low of compression (low for a all-motor build). You can easily get 87,88,or 89mm 11.5:1 Wiseco's. Or talk to Jeff at Import Builders and get some 12.5:1's like what I had and was going to run:
