clutch replacement
Old Feb 7, 2005 | 10:31 AM
wereami's Avatar
Default clutch replacement
I am going to replace my clutch this weekend. I was wondering if it is easier just to pull the entire engine from the car or just the tranny. b18a1. I am doing all the work solo. If anyone has done this solo let me know.
Old Feb 7, 2005 | 10:37 AM
EP3_05's Avatar
Default Re: clutch replacement (wereami)
Doing it solo is not fun...been there done that. Dropping the trans requires some work but not as much as pulling the entire engine out. It will be quicker to just drop the trans that remove the entire engine.
Old Feb 7, 2005 | 10:43 AM
wereami's Avatar
Default Re: clutch replacement (91civic)
thanks dude.
Old Feb 8, 2005 | 02:35 PM
tehBullet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">Doing it solo is not fun...been there done that. Dropping the trans requires some work but not as much as pulling the entire engine out. It will be quicker to just drop the trans that remove the entire engine.</TD></TR></TABLE>
true
Old Feb 8, 2005 | 02:56 PM
EF9TORRES's Avatar
yeah, just pull the trans. and try to get the car high enough pull the trans out from under the body. and if you can try to borrow impact tools and an air compressor. that will make your 8 hour (hand tools only) job a 3 hour so sweat job.
okcdc2
Jan 14, 2012 11:37 PM
whagkangmakulet
May 11, 2003 08:57 AM
ScottEK
16
Sep 26, 2002 09:35 PM
JD_B18CDX
Jan 28, 2002 11:04 AM
