Anyone using Rocket M22s on PCTs???
My friend is building an LS/VTEC with .25 PCTs and was wondering if the Rocket M22 camshafts will work in conjuction with these high Domed pistons......
The head (PR3) will have either TODA Dual springs and OEM Retainers or might just go with Rocket valvetrain.... Valves, however, will stay OEM....
So, can anyone tell us, if this is safe to use??? Looking for 190s whp in 1.8 litre, not sure if 200 whp is attainable....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgirl007 »</TD></TR><TR><TD CLASS="quote">people run those with CTRs all the time, so you'd probably be ok.</TD></TR></TABLE>
PCT pistons in a B16B's different than PCT pistons in a B17a or B18a
My B17a with PCT pistons:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>that looks so beautiful
..if only we had 94 octane here
I remember when 76 started selling 100 octane here in CA for 4.75 a gallon. Everyone was freaking out trying to get it. Lame. Theres always Toulene.. Hah so many gangster toulene threads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soLSvtec12kcraze »</TD></TR><TR><TD CLASS="quote">200whp is easily attainable with m22's....</TD></TR></TABLE>
unless your vteckidd and then you will make the same power itr cams do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Transistor »</TD></TR><TR><TD CLASS="quote">
unless your vteckidd and then you will make the same power itr cams do.</TD></TR></TABLE>
Haha, yeah I saw his car on the dyno this weekend in ATL and it make like 182whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevanitygroup »</TD></TR><TR><TD CLASS="quote">I remember when 76 started selling 100 octane here in CA for 4.75 a gallon. Everyone was freaking out trying to get it. Lame. Theres always Toulene.. Hah so many gangster toulene threads.</TD></TR></TABLE>
76 USED to sell 100 octane. They got out of the Race gas business a few years ago. The guys that ran the program for 76 opened Rockett Brand racing fuel.
Some 76 stations still sell 100 octane. That stuff is actually VP MS100.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">vteckidd had tuning issues with his car.</TD></TR></TABLE>
yeah im sure he did...
and you wouldnt be saying that because..."Whoopee Doo Racing Dealer for Rocket Motorsports"
I thought he has made like 60pulls on the dyno with that thing?
Yep but we dont need to be dealers to see that the m22 on the vtec lobe is = to the new skunk Pro 1's in power..
OMG guys,
i am a good friend of vteckidd, and i can vouch for the sickness of these cams.
i did the tuning, i did the installation, and i did the valve adjustments, and cam gear adjustments....
the head on his engine is a stock b16 first gen head. i can almost guarantee that with a ITR head, or even a 2nd gen b16 head, his #'s would jump.
now, since someone said something about tuning, i have tuned quite a few local cars, from 250whp to my lowly b16 coming in at 157whp (it dyno'd on sunday at 150whp) and all i can say is that we got over 20whp on his engine from tuning.
if anyone has any beef's please keep it to pm's. this thread isint about mikes engine, its asking if m22's will hit the pistons...
i think they will be fine as long as your using a b16 head. i used s2 stage2 cams on it and had 2-4 degrees positive i believe on both cam gears
ok where to start
Fo those that are interested, heres the results from sundays DYNO DAY AT MAINSTREAM PERFORMANCE
4 Cylinder
00 Civic Neil Wisham 1.8L @ 112.09 HP per ltr = 201.76 HP
91 CRX Mike Corvey 1.8L @ 101.33 HP per ltr = 182.39 HP
95 Integra Jason Thammarong 1.8L @ 100.36 HP per ltr = 180.65 HP
94 Civic Andrew Bost 1.6L @ 96.99 HP per ltr = 155.84 HP
94 Civic Jesse Bradley 1.6L @ 96.38 HP per ltr = 154.21 HP
90 Civic Jonathan Murphree 1.6L @ 93.93 HP per ltr = 150.29 HP
94 Civic Sara VanHuben 1.6L @ 93.59 HP per ltr = 149.74 HP
05 RSX Alamar Tinsley 2.0L @ 93.06 HP per ltr = 186.12 HP
90 CRX Kevin Tran 1.6L @ 92.86 HP per ltr = 148.58 HP
93 Civic Peter Nickelson 1.6L @ 88.75 HP per ltr = 142.00 HP
89 CRX Danny Franzek 1.6L @ 84.17 HP per ltr = 134.67 HP
98 Civic Shawn Samani 1.8L @ 81.77 HP per ltr = 147.18 HP
91 Integra Ben Woods 1.8L @ 78.57 HP per ltr = 141.26 HP
94 Civic David Wallis 1.6L @ 74.08 HP per ltr = 118.52 HP
93 NX2000 Kevin Boyce 2.0L @ 73.10 HP per ltr = 146.20 HP
94 Civic Rhyne Runels 1.6L @ 69.93 HP per ltr = 104.89 HP
Thats right i took second. THe guy who beat me made his numbers with 1 point higher compression and engine managment and an ITR head. Not taking anything away from him, he put down good numbers, but just showing there are differences between our motors.
I tell all my customers not to take my dyno numbers seriously, the most i have made on a dynojet was 185whp. I am tuning with a VAFC, 1st gen B16 head. all these guys making 190whp + in atlanta have Hondata, Chrome, Uberdata, ITR heads,12.0+compression ,2.0 ,etc. not making excuses , i want higher numbers, but it is what it is. Before ANYONE TALKS **** ABOUT MY MOTOR, find out the information first.
I gained 23 Ft/Lbs of TQ and 21 WHP in the MIDRANGE just by dropping Rockets Camshafts into my car. I gained about 15whp on top end. Theres no doubt his cams make power. why are my numbers low, ill tell you
1) oil consumption problem i have had since DAY ONE of this motor, prob bad valve seals
2) VAFC, ive had to pull 20-30 fuel out, which affects timing , which i have no control over
3) 1st gen head, WORST flowing head honda ever made, STOCK no valvejob, porting, NOTHING, and it shows on my dyno.
4) Ran out of fuel, when i hit vtec , i drop 12psi in pressure (stock DX fuel pump)
Transistor, what motor do you have thats so powerfull? just curious why you can talk **** when i dont even know you and you dont know me. Everyone talks **** about how much their motor makes, when in the end, out here in atlanta its ALL BULLSHIT. there arent TONS of 190-200whp car roaming around like everyone thinks. i see it at every dyno day and every dyno session. Lube i take it is BIGDAWG, yeah i made over 100 dyno puls with my car testing various things out. in the end it was always the same problems, unported head, not enough fuel.
Its really sad how i only make 185whp and im one of the fastest cars in atlanta all motor. i guess a 2200 lb chassis does that for you. If anyone wants to discuss furhter, keep it out of this thread, and PM me.
To the kid that started this thread, sorry for all this , this is stupid, it will go to PMs now. TO answer your question, clay the motor, but you should have enough room if you choose Rocket Motorsports M22s, i highly reccomend them.
ok where to start
4 Cylinder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD »</TD></TR><TR><TD CLASS="quote">
ok where to start
4 Cylinder
To the kid that started this thread, sorry for all this , this is stupid, it will go to PMs now. TO answer your question, clay the motor, but you should have enough room if you choose Rocket Motorsports M22s, i highly reccomend them.</TD></TR></TABLE>
Can I get a WOO WOO!
Anyway, lube is not BigDawg, as for the M22's only in what I have seen (with my own eyes, in person) I am not too impressed. The idle is sick! However the power is just not there, this maybe due to tuning and fuel, but the power is just not there.
ok where to start
4 Cylinder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smote »</TD></TR><TR><TD CLASS="quote">
Anyway, lube is not BigDawg, as for the M22's only in what I have seen (with my own eyes, in person) I am not too impressed. The idle is sick! However the power is just not there, this maybe due to tuning and fuel, but the power is just not there.</TD></TR></TABLE>
lets put 'em in ur car
Anyway, lube is not BigDawg, as for the M22's only in what I have seen (with my own eyes, in person) I am not too impressed. The idle is sick! However the power is just not there, this maybe due to tuning and fuel, but the power is just not there.</TD></TR></TABLE>lets put 'em in ur car
as i said, dont take my motor as "proof" of what they can do. these cams havent gotten an honest shot on my motor due to fuel and tuning issues as i said before. I have never represented my motor as being "the greatest most whp all motor " engine etc. I m happy with it, and the 2.0 motor i have is a much hotter motor that ill have dynoes of shortly wioth m22s and a head that can flow. might i add that with an ITR head and some sort of tuning system i bleive i can hit 200whp. but i guess we'll see
chech out this STOCK BOTTOM END ITR motor
New Set-up 223whp / 145 tq on most recent re-dyno. 230+ with Shawn Church Magic Intake.
Graph shown is 215.8whp initial dyno.
Intake: Same
Throttle Body: Same
Intake Manifold: AEBS
Injectors: Same
Camshafts: M22 254 duration @ 0.050. 12mm Lift In/ Ex
Springs/Retainer: RM G1 Springs / G2 Ret 95lbs on the seat, 265 at 12mm
Valves: Supertech 33.0/28.0 Int/Ex flat faced valves
Cylinder Head: RM J4 B16 Head. High Flow / Low Turbulence Ports. Milled 0.025
Cam Gears: Same
Bottom End: Same
Compression Ratio: 11.2
Header: Same
Exhaust: Buddy Club
Fuel Management: Hondata S200
all this info is on Rockets Website http://www.m24x.com.
Smote, care to do a dyno test with m22s?
Intake: Same
Throttle Body: Same
Injectors: Same
Cam Gears: Same
Bottom End: Same
Header: Same
Exhaust: Buddy Club
