Tire size question
I am looking to get new rims and tires for my 99 civic ex. I am running h&r sports for lowering springs. I am thinking of gettin 16x7 rims but my question pertains to how wide of a tire can I get before i have to worry about rubbing. Rolling the fenders is also not an option since i don't want to spend the extra money for it. I was thinking of running 215/40/16 but I am not sure if that is pushing it. I don't want to go any lower than 40 for sidewall height due to the bad roads which I travel and I dont' want to dent the rims. Any input would be much appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ocdcivic »</TD></TR><TR><TD CLASS="quote"> I am looking to get new rims and tires for my 99 civic ex. I am running h&r sports for lowering springs. I am thinking of gettin 16x7 rims but my question pertains to how wide of a tire can I get before i have to worry about rubbing. Rolling the fenders is also not an option since i don't want to spend the extra money for it. I was thinking of running 215/40/16 but I am not sure if that is pushing it. I don't want to go any lower than 40 for sidewall height due to the bad roads which I travel and I dont' want to dent the rims. Any input would be much appreciated.</TD></TR></TABLE>
for 16in on an ek, i say go with 205-40-16
I have a set and there a few other people on here that run 215/45/zr16's.
If you want to run soft suspension and be dumped yu will need a camber kit.
But if you are going to run some high spring rates and have your car lowered 2 inches or less. you should be ok.
Yeah I am at about a 2 inch drop with my h&r sports and I actually have a camber kit so I am looking to go with a 215/40/16 tire with a 40mm offset if possible. If not what offset would I need?
As long as I dont have to take out any more Metal Gears
205/40 are cool, but u will get a bumpier ride. A lot of the people i know that have 16's always get the 205/45. And for some reason, 205/45 are a bit more expensive than 205/40. Go figure...
Ill Mitch
Jan 9, 2007 05:58 AM
