need help with mpfi swap
my friend started mt mpfi while i was at work, and he didn't label any connection and none of the hoses.
Does anyone have a diagram of all the hoses and connections?
http://www.4thgenerationcivic.com/ho...conversion.htm
http://www.fourthgenhatch.com/mpfi.html
this topic has been covered many times, use search if you cant find whats what
From: I told you to wait in the truck in Texas, United States
Also look in the FAQ section at the top of this forum for more links..
yea,i already know about that site,that's where i got all my info for this swap i just need to know where all the vaccum lines go too.
http://www.binghamtonlife.com/...3.jpg there u go 4 coolent lines
https://honda-tech.com/zerothread?id=1131859 theres some vacume questions i had
It helps if you tell us what you are working on..
You probably need a U shaped coolant hose for the Si model.
for an '88 model:
This link has a vacuum map for a '91
https://honda-tech.com/zerothread?id=1120716
for an '88 model:
